Cleaned out the garage
Time for a little spring cleaning. lots of pictures. all prices are best offer. POST HERE FIRST IF INTERESTED IN SOMETHING. I WILL TAKE INTEREST HERE FIRST, THEN PMS. shipping will be actual, paypal add 3.5% or i will accept money orders. thanks
black 4 speed 4wd carpet, very nice, used for about 500 miles(just leaves in picture)-$75 5 350 manifolds from chevelle/monte carlo-10 each or 40 for all 7 highlander hubcaps-$25 custom camper/20 emblems-$100 custom camper door script-$20 gmc 1500 super custom-20 rest of em-12 pair, 8 each 1979 owners manual-5 350 fan shroud(just dirty, all mounting tabs perfect)-50 2 radiators(4 speed), one's bigger than other-50 for bigger, 35 for smaller big block front springs(2 sets)-65 per set 2 454 air cleaners-25 each 350 2 barrel air cleaner-17 72 only 350 engine stands(have cups with them)-make offer 5 blade fan-15 set of driver quality gmc headlight rings-20 blazer vent tube-75 2 manual throttles for parts-10 67-68 e brake-offer? 69-72 e brake-offer? hurst 4 speed stick-15 blazer top to body hold downs-50 for set, 30 each door caps-55 each set hatch access plates-55 for 2 sets(no t handle access covers) 350 alternator brackets-35 4 speed knobs-12 each 73 up under column cover-25 http://img.photobucket.com/albums/v2...g?t=1242540124 http://img.photobucket.com/albums/v2...g?t=1242540162 http://img.photobucket.com/albums/v2...g?t=1242540276 http://img.photobucket.com/albums/v2...g?t=1242540305 http://img.photobucket.com/albums/v2...g?t=1242540402 http://img.photobucket.com/albums/v2...g?t=1242540444 http://img.photobucket.com/albums/v2...g?t=1242540506 http://img.photobucket.com/albums/v2...g?t=1242540535 http://img.photobucket.com/albums/v2...g?t=1242540639 http://img.photobucket.com/albums/v2...g?t=1242540710 |
Re: Cleaned out the garage
i`m interested in the Hurst shifter.
Q?:What`s driver shape about the GMC headlight doors?Just chrome getting weak? |
special-k, one is still nice 'n shiny, but has a few dings, etc. the other i haven't even cleaned up. i will clean them up and take a better picture. thanks for the purchases, you two have pms
ok.That looks like a long one in the picture.I have one from a Blazer with His`n`Hers (auto/cable) shifter,but it`s pretty rusty.I`ll be needing one for my 2wd w/M22.
how much for the blazer striker plates?
is the fan clutch? if so, interested in it and shroud...
woodymm, i'm guessing you mean the hatch to body brackets? They are 50 for a set.
coachmeason, the fan is just a regular fan, not a clutch fan. the shroud is very nice. lmk. special-k, here's a better picture. the one headlight bezel is dulling. the other would be a very nice driver bezel. i also included a picture of the shifter. thanks, doug http://img.photobucket.com/albums/v2...g?t=1242591293 |
Hello,
Is the carpet small hump or high hump? I have both combinations in my two trucks. Will the 454 aircleaner fit a four barral carb? May be interested. R/ |
The carpet is for a 4wd, so high hump. The 454 air cleaners are both 4 barrels air cleaners. thanks, doug
Doug,I got my shifter out and it`s from a manual.Not the one I thought.I think it will work for me.What does yours measure from the center of the upper bolt hole to the knob?.I`m still interested in the headlight doors.
pic # 8. what do the air cleaners fit? I need one that will fit a 1 brl shipped to 78210
Thanks Ralph Sorry I just saw they are for 2 454 air cleaners-25 each and 350 2 barrel air cleaner-17 :whine: |
15 3/8" about special k from center of top bolt hole to end of knob. thanks and let me know
OK...What do you think shipping is to 73572? OKlahoma
I just did a quick quote and it looks like 15 or so. If that's reasonable, I'll package them and run them down to UPS for an exact price. let me know. thanks
Hi Doug,
What kind of deal can you make on both shipped to 93555? R/ |
I hate to say it,but I need to pass.They are good parts for good prices.I just can`t do it right now...thanks & sorry
longhorn, you have mail!
special-k, no problem. |
Here's an updated list. thanks
black 4 speed 4wd carpet, very nice, used for about 500 miles(just leaves in picture)-$75 (pending) 5 350 manifolds from chevelle/monte carlo-10 each or 40 for all 7 highlander hubcaps-$25 custom camper/20 emblems-$100 custom camper door script-$20 gmc 1500 super custom-20 rest of em-12 pair, 8 each 1979 owners manual-5 350 fan shroud(just dirty, all mounting tabs perfect)-50 (pending) 2 radiators(4 speed), one's bigger than other-50 for bigger, 35 for smaller big block front springs(2 sets)-65 per set 2 454 air cleaners-25 each (1 pending) 350 2 barrel air cleaner-17 72 only 350 engine stands(have cups with them)-make offer 5 blade fan-15 set of driver quality gmc headlight rings-20 blazer vent tube-75 67-68 e brake-offer? 69-72 e brake-offer? hurst 4 speed stick-15 blazer top to body hold downs-50 for set, 30 each door caps-55 each set hatch access plates-55 for 2 sets(no t handle access covers) 350 alternator brackets-35 4 speed knobs-12 each 73 up under column cover-25 |
PRICES REDUCED
black 4 speed 4wd carpet, very nice, used for about 500 miles(just leaves in picture)-$75 65 5 350 manifolds from chevelle/monte carlo-7 EACH 7 highlander hubcaps-$25 20 custom camper/20 emblems-$100 80 custom camper door script-$20 15 gmc 1500 super custom-20 15 rest of em-10 PAIR 1979 owners manual-5 4 350 fan shroud(just dirty, all mounting tabs perfect)-50 42 2 radiators(4 speed), one's bigger than other-42 for bigger, 30 for smaller big block front springs(2 sets)-65 per set 55 2 454 air cleaners-25 each 20 350 2 barrel air cleaner-17 14 72 only 350 engine stands(have cups with them)-make offer 5 blade fan-15 10 set of driver quality gmc headlight rings-20 16 blazer vent tube-75 62 67-68 e brake-offer? 69-72 e brake-offer? hurst 4 speed stick-15 12 blazer top to body hold downs-45 for set, 25each door caps-55 each set 48 hatch access plates-55 for 2 sets(no t handle access covers) 48 350 alternator brackets-35 28 4 speed knobs-12 each 8 73 up under column cover-25 17 |
Hi 68350, Can you give me a general description of the condition of the custom camper/20 emblems? Do you have a close up pic? Thanks, Dwayne
I will dig them out in the morning and get a close up. They're pretty nice, but will need to be repainted.
Hi Doug,
I re PM ed ya. Hey, in the picture with the air cleaners in it. I was curious what the top one was? R/ |
350/265 horsepower for a 2 barrel off of a 71 chevelle. the carpet and 1 454 air cleaner sold! thanks longhorn.
Updated list:
5 350 manifolds from chevelle/monte carlo-7 EACH 7 highlander hubcaps-$25 20 custom camper/20 emblems-$100 80 custom camper door script-$20 15 gmc 1500 super custom-20 15 rest of em-10 PAIR 1979 owners manual-5 4 350 fan shroud(just dirty, all mounting tabs perfect)-50 42 2 radiators(4 speed), one's bigger than other-42 for bigger, 30 for smaller big block front springs(2 sets)-65 per set 55 454 air cleaners-20 350 2 barrel air cleaner-17 14 72 only 350 engine stands(have cups with them)-make offer 5 blade fan-15 10 set of driver quality gmc headlight rings-20 16 blazer vent tube-75 62 67-68 e brake-offer? 69-72 e brake-offer? hurst 4 speed stick-15 12 blazer top to body hold downs-45 for set, 25each door caps-55 each set 48 hatch access plates-55 for 2 sets(no t handle access covers) 48 350 alternator brackets-35 28 4 speed knobs-12 each 8 73 up under column cover-25 17 |
