-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   i know this is gunna me me seem like an idiot (https://67-72chevytrucks.com/vboard/showthread.php?t=345000)
pokethesmot 05-22-2009 12:34 AM
but how do i add fluid to my np208 transfer case i know this fill plug is at the way top but i cant get the bottle angled right i only tried adding fluid once and i just made a mess...so can some one help me out
special-K 05-22-2009 06:05 AM
Re: i know this is gunna me me seem like an idiot
"This is gunna me me seem like an idiot?",how so?:haha:
Sorry,that was funny to read :lol:.It`s a tough thing to do.Can you fashion a tube to the bottle and squeeze it?(may need a teeny hose clamp)Shops use a pump and a hook-shaped nozzle.I fill before install and have shops check/fill mine.I know that gunna me me look like a lazy idiot.:lol:
duallyjams 05-22-2009 06:19 AM
When you add fluid to the axle you have do the same way,a plastic bottle that you can squeeze with a hose on the end.
OLDCHEV4X4 05-22-2009 07:11 AM
I put the cap from a gear lube bottle, on a quart of trans fluid, and squezze.
Eturnit3 05-22-2009 11:00 AM
+1:metal:
72 CustomCamper 05-22-2009 11:16 AM
My neighbor went to the dollar store and bought a cheap turkey baster. Worked great...
Chuck
liftmeup 05-22-2009 11:26 AM
hose on the bottle or remove the 4x4 lever boot and run the hose down into the case and use a funnel all the same diffrence just get it in there.
dammitmitchell 05-22-2009 12:00 PM
turkey baster or a hand pump both are avail at walmart for under 5 bucks..
special-K 05-22-2009 03:27 PM
I`m a carpenter,I use a chaulk bottle.
I knew a waitress who used a mustard bottle for gear oil and a ketchup bottle for dextron.(not really)
lyrikz 05-22-2009 06:11 PM
Your username already has that taken care of... ;)
