__ 0.25" Trailing arm shim for your coil spring rearend
1.4" thick trailing arm shim fits any rear coil spring truck. Use it to level off an uneven truck, use as a template to make lowering blocks, use it to offset (on the left side) your full length Panhard bar mounting bracket (on the right trailing arm). The "peely stuff" you see in the picture is paint.
$11 shipped to your US address. I'll take dibs in the order received. I can do Paypal, or check/mo by mail. If you want to know who you're dealing with, I'm "labboypro" on ebay and heatware, with 12+ years of positive fb. |
Re: __ 0.25" Trailing arm shim for your coil spring rearend
bumpalicious
Anyone? Bueller? Anyone?
This is going in the recycle bin soon. Save it from this horrible death.
