-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   transmission help (https://67-72chevytrucks.com/vboard/showthread.php?t=355344)
bfay17 07-30-2009 11:32 AM
transmission help
Okay guys here's what i'm planning on 8 inches of lift and 15.5 inch wide 38 inch tall tires. Im building a 450+ horse 454 and i as wondering if a sm465 or if a newer style nv4500 would be a better choice. The truck is going to see the road but its also gonna be run in some mud and put in pulls. Thanks
martindc1 07-30-2009 11:47 AM
Re: transmission help
The last truck pull I was at, all the manual transmission trucks had sm465s, so I'm thinking one should work for you just fine. It will be easier and cheaper than a NV4500. I think the choice between the two really depends on how bad you want overdrive.
bfay17 08-02-2009 04:11 PM
Okay that's kind of what i was thinking. Overdrive doesnt really matter much to me i was just thinking one might be better than the other but thanks that means more money into the body.
bad421 08-15-2009 11:47 PM
sm465 all the way. i hear that the nv4500 has a bad problem with 5 gear anyway.
