8 lug stud spacing
I found this killer dealer on a set of wheels http://northmiss.craigslist.org/pts/1305110606.html , but don't the 8 lugs for '99 F250 use that 170?mm stud spacing instead of 6.5"? I really wish they would fit...is there any way it could work?
Re: 8 lug stud spacing
Correct they are 170mm. The only way it will work is with adapters
I saw one time where a guy that had a sweet 91 F-350 had 02 super duty 8 lug alloy wheels on it. The guy owned a machine shop and machined the wheels and added an offset slug that he also machined and was able to bolt the wheels to his standard truck. It seems like a lot of work though.
It seems to me that 6.5 inch bolt diameter pattern is 165.1mm
And 170mm is 6.69 inch Therefore the difference in diameter is only .095 inch 10 thousandths is not very much If my math is correct The more important question will be if the backspacing is correct. The high offset wheels have a problem clearing early tie rods and brakes and... Just my two cents Mick |
Good input Mick.
5 millimeters is essentually 3/16" The difference (english) between 6.5 and 6.69.....is .190 (not .095) .190 is close enough to 3/16" (.187) So, what it all comes down to is....does 3/16 matter? IMHO, yes. The wheel "might" physically fit over the lug studs, but the nuts will never tighten properly. They will bind on the edges of the taper before seating. THis will stress the studs. Of course all of this is moot if the off-set doesn't "work" |
If you tried to run those Ford wheels on an 8 on 6 1/2" hub, the lug nuts would come loose on one side of the truck very quickly.
I once had a set of 170 mm rims on a 6.5in 8lug chevy (because I was told they were 6.5in) and it had a wicked hop going down the road. So your answer is yes it does make a differance, and belive me when I say this, it is unsafe.
Again all of this math. The real world is something different. I did bolt on a set of late model wheels on my early model dana 60 no problems with the lug pattern but the offset stopped everything. 10 thousandths is not much in a 6.5 inch diameter space, but are late model truck wheels hub centric or lug centric? Mick |
Blazer1970 OK 10 thousandths is to much and therefore Ford wheels will not fit on 6.5 inch diameter bolt patterns. Mick |
Have a machine shop drill a new 8x6.5 pattern in between the 8x170 holes.
