-   The 1969 - 1972 Blazers and Jimmys Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=36)
-   -   Mordachai- High Rise Fiberglass Fenders- Group Buy (https://67-72chevytrucks.com/vboard/showthread.php?t=357757)
Mordachai 12-19-2007 09:09 AM
To discuss this topic go here- LINK
Group buy for
___________________________________________
High rise / radiused fiberglass fenders
These are fiberglass fenders with wheel openings that are 4" longer and 2" taller with a factory look.
Great for slammed trucks or lifted trucks looking for a little more wheel/tire clearance.
67-72 GMC & 67-68 Chevy style fender:
http://i17.photobucket.com/albums/b6...s/IMG_6134.jpg
http://i17.photobucket.com/albums/b6...s/IMG_6158.jpg
69-72 Chevy style fender:
http://i17.photobucket.com/albums/b6...s/IMG_6392.jpg
http://i17.photobucket.com/albums/b6...s/IMG_6389.jpg
These are top quality parts, ready to fit and 'scuff and spray'.
There are no pinholes, bubbles in the laminate,
or other problems often associated with fiberglass.
Sub-par parts will NOT be shipped out- EVER.
Each fender will be warrantied against manufacturing defects
for a period of one year from purchase.
Option 1-
Outer skin only:
This can be bonded to the 'frame/skeleton' of your existing fender, or have custom mounts built.
Option 2-
Full fender with factory mounts:
This will bolt to the factory locations, 2 bolts on cowl, 1 bolt on lower A pillar, and factory bolts on the Core support. This fender will require some fabricating to brace the cowl support in position(preferably from firewall/cowl to core support). Additionally you will need to fabricate new mounts for your hood. This can be done either by installing firewall/cowl hood hinges or fabricating mounts to use the stock hood hinges. Dropped trucks will probably need firewall/cowl mounted hinges, 4x4 trucks can use whatever method is found suitable.
Standard Pricing:
Option 1-a Lay-up with gelcoat, vinyl-ester resin, woven cloth and 2mm core = $350
Option 1-b- Lay-up with gelcoat, Poly-ester, CSM and 2mm core =$300(CSM- chop strand mat)
Option 2-a- Gelcoat, Vinyl-ester resin, 2mm core and woven cloth = $475
Option 2-b- Gelcoat, Poly-ester resin, CSM, 2mm core = $425
Shipping is going to be either UPS ground oversize, UPS Freight, or truck freight, your preference. shipping will vary due to buyers location, ships from zip 33414. I have sourced 'oversize' shipping boxes that will work perfectly for the fenders, and all other packing materials.
Group buy pricing
prices are Per fender.
GB pricing for total overall sales, not for each separate option
Option 1A
Retail: $350
1-5 committed :$325
6+ committed : $300
Option 1B
Retail: $300
1-5 committed :$275
6+ committed : $250
Option 2A
Retail: $475
1-5 committed: $450
6+ committed: $425
Option 2B
Retail: $425
1-5 committed: $400
6+ committed : $375
Committed sales require min. 50% deposit, Balance & shipping due upon completion.
Payment through paypal, MO or personal checks.
available now: 67-72 GMC style and 67-68 Chevy style
available early october: 69-72 Chevy style
Lead time for 1 pair of skins = 2 weeks after 1st GB rate reached
Lead time for 1 pair of fenders with bonded mounts = 3 weeks after 1st GB rate reached
