-   -   Steering Column Help (https://67-72chevytrucks.com/vboard/showthread.php?t=367167)
ghettoluxury 10-13-2009 11:50 PM
I bought a tilt column from a 73 today for $20 to put into my 82. Upon inspection of the 2 columns I noticed that the plug for all the large wires on the 82 is flipped 180 degrees. So I was wondering if it will be a plug and play or will I have to do some re-wiring.
N2TRUX 10-14-2009 08:21 AM
Re: Steering Column Help
There were 2-3 different configurations between 73-87 so it's hit or miss. Check your steering shaft as well. There was a change in the shape mid 70's.
ghettoluxury 10-14-2009 02:51 PM
Ya the shape of the shaft was different so when I pulled it I took shaft that goes to the box also. guess I'll put it in and go from there
ghettoluxury 10-14-2009 04:54 PM
Well I put the new column in. The turn signals work and the truck starts but no flashers so good enough for me.
Jonboy 10-14-2009 06:26 PM
repin the plug on the column to match the one in the truck. The shape of the plastic plug is different, but the wires are in the same location.
ghettoluxury 10-14-2009 08:24 PM
just had to cut off a locking tab and flip the plug upside down but it works great
