-   -   what a day check it out Please (https://67-72chevytrucks.com/vboard/showthread.php?t=370637)
1979blkchevy 11-06-2009 01:14 PM
Ok got up thismorning started up my truck and it made one hell of a grind/squeel sound then it stop let it warm up for a while no squeel or grinding sounds as it idles I get into the truck take off down the road and it did that squeeling sound/grinding sound again i stop the truck and got out popped the hood went to turn the truck off and the darn thing wouldnt shut off so i went out anyway to check under the hood and there was alittle steam coming from one of the valve covers so i got back in the truck and came back home and itmade that grinding sound all the way home about 4 blocks so i went to get some tools to unplug the battery when i came back the truck was already shut off!! Can annyone give me any ideas on what happen or what i should start replacing and ect thanks aot for everything
LONGHAIR 11-06-2009 01:41 PM
Re: what a day check it out Please
Does this truck have Air Conditioning?
1979blkchevy 11-06-2009 02:36 PM
Originally Posted by longhair (Post 3605860)
does this truck have air conditioning?
no ac
dan76 11-06-2009 04:36 PM
How about engine/trans info. Is it equipped with an air pump?
1979blkchevy 11-06-2009 04:47 PM
Originally Posted by dan76 (Post 3606054)
how about engine/trans info. Is it equipped with an air pump?
no air pump has a mildly built 350 and a 350 tranny nothing done to it
Zoerb 11-06-2009 05:09 PM
i would look at the wires on the starter, and see if they are almost touching or are melted. then I would get the starter checked. I had a 79 suburban that the starter stayed engaged and it had burned up the battery and was makeing the same noises that your describing.
which valve cover is the steam coming from?
billnorman 11-06-2009 07:11 PM
Great answer. Prolly shorted wires to starter OR stuck solenoid.
1979blkchevy 11-06-2009 07:20 PM
it sounds as if i try to start it now that i can hear the fly wheel spinning but it seems the starter isnt catching on any of the teeth i got it started once then i tuned it back off tried again and the start seem not to catch on something to turn the motor does this make sence?? thanks for the reply the steam was coming from the right side
68 TT 11-06-2009 07:21 PM
The starter wiring sounds like a good place to start. It may have gotten melted and is keeping the solenoid engaged longer than it should.
It may be melted plastic smoke you are seeing and not steam.
68 TT 11-06-2009 07:23 PM
Having the solenoid stuck my have caused some flywheel or bendix gear damage when the engine fired up so the teeth are not engaging in all areas of the flywheel.
1979blkchevy 11-06-2009 07:43 PM
thanks alot im going to tear it apart tommorow thanks for everything
1979blkchevy 11-07-2009 02:36 PM
thansk for everyones help problem is solved it was the starter and the wires were alittle fried and melted but its all fixed now thanks again
Zoerb 11-07-2009 03:28 PM
Glad to help!:bann:
1979blkchevy 11-07-2009 03:37 PM
Originally Posted by Zoerb (Post 3607310)
Glad to help!:bann:
maybe you could help with my driveshaft problem check it out
