-   -   Lowering spindles? (https://67-72chevytrucks.com/vboard/showthread.php?t=372612)
1LowToy 11-18-2009 10:23 PM
Lowering spindles?
I've located some lowering spindles. The spindle arms come with both spindles for the 1.0" or 1.25" thickness rotors. The problem is I would have to pressout the spindle from the arms and press in the correct spindle for my truck. Is this common?
Options=
Change out the spindles to fit and weld the spindle from the back side?
Hold off and find the right ones.
What determines the rotor size difference? Is there a rule of thumb?
Small block= 1.0"?
Big block1.25"?
Long bed 1.25"?
Tow package 1.25"
Mine is a shortbed L6 so I'm thinking I have the 1.0". It's too cold out for me to check tonight.
lolife99 11-18-2009 10:44 PM
Re: Lowering spindles?
This is not common for a '73-'87 truck.
Sounds like some cheap Aim/Airbagit junk spindle.
Skip these.
Get a good quality spindle that is correct for your width rotor. Period.
lolife99 11-18-2009 10:46 PM
I believe the 1" rotors started in 1981.
I never understood why GM made two different rotor thicknesses.
sailed2japan 11-18-2009 11:20 PM
I'm no engineer, but It seems to me that a thicker rotor can take more heat w/o warping. If they did a 100% change in 81 I would think it was to either save money by buy less steel or because better material was available. Remember that one of the reasons new vehicles have thin panels is so car companies can save money, but the price of cars goes up every year??
lolife99 11-18-2009 11:43 PM
No reason. No year specific.
Some trucks had 1" LD rotors and some had 1.25" HD rotors.
I assume the cheaper 6 cylinder/plain jain trucks got the lighter rotors.
My '86 silverado had 1.25" rotors,... and my '83 small block stepside (equipped with a lot of options) had 1" light duty rotors.
Who knows,...
3r!c84 11-18-2009 11:50 PM
yeah i got a fully loaded 84' silverado and it only had 1in rotors
3r!c84 11-18-2009 11:51 PM
wheres Keith when you need him? :lol:
