-   Engine & Drivetrain (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=24)
-   -   anyone here ever built a 406 (https://67-72chevytrucks.com/vboard/showthread.php?t=378835)
blindman 01-01-2010 02:19 AM
im thinking fuel injected pump gas torque monster:smoke:
63 & 64 Bowties 01-01-2010 08:05 AM
Re: anyone here ever built a 406
blindman, I moved this for you to the engine & drivetrain section.
And, welcome to the forum from right up the road from ya.
cdowns 01-01-2010 08:20 AM
i've built some 406's in the 70's but they were all fords
Kateaux 01-01-2010 10:18 AM
If you are talking about a 400 SBC based engine, be sure to have plenty of radiator. They require about the same cooling as a big block.
K8O
72HULK 01-01-2010 07:03 PM
I am currently having one built. One of my buddies I work with is doing all of the work. I initially considered stroking the motor to 415 or 421 but I decided against it. Now I am going for internally balanced w/ 6" rods 10.5-11.0 to 1 CR and aluminum heads. It will be going in my 72 4x4.
884x4Sub 01-02-2010 01:57 AM
406 efi?......I thought about doing it with my 88 tbi Sub......found getting a tbi to work properly with a big power engine is a bit of a crapshoot.....and the aftermarket efi systems are pretty pricey(2Gs and up)......eventually I sold the whole truck and bought a carbed '85 that I can drop in a big power carb 406 in (smog) legally.
PhilaTruck 01-04-2010 12:09 AM
You'll like it well enough. Mine stays around 170 with new stock replacement radiator.
I was all over "other" induction systems. If you're not doing the work yourself, pick the system that your mechanic knows best.
Welcome to the board-
-Todd
Autometer 01-04-2010 07:14 PM
3 Attachment(s)
I'm building one too. I just need to put it together and get it dyno'ed.
Trick flow heads 2.100/1.6
Custom JE pistons to match heads
6.0 Eagle rods.
Stock stroke compstar crank
Isky solid roller
CC pro magnum 1.6 rockers
750 proform carb
Engine was going in a '78 Malibu but I'm consolidating my projects so the truck stays and gets the poweplant.
PhilaTruck 01-04-2010 09:16 PM
Jeez Autometer, what's the compression with those pistons and heads? Those combustion chambers look like 58s.
crapy67 01-04-2010 09:27 PM
I built a 406 for my 71 nova this past spring, and it made 540hp at the crank, I ran it hard all summer long and the temp never got over 180 degrees even during the break in. Good luck with your build.
Autometer 01-05-2010 02:04 AM
Guessing on the piston CCs it came out to 12.75:1 but I haven't built it so I really don't know. The heads used to be 67 out of the box but they've been opened up and resurfaced a couple times in it's life time.
