-   -   Adding AC?? (https://67-72chevytrucks.com/vboard/showthread.php?t=384608)
BGRAFX 02-02-2010 08:35 AM
Adding AC??
How hard is it to Add Air Conditioning? I've looked at 3 trucks recently an 88 crewcab, a 78 blazer and a 83 suburban and none of them had AC....The trucks were priced cheap but not cheap enough for me to buy without AC unless of course its an easy add on.
Thanks Guys
95 S_Trucker 02-02-2010 09:03 AM
Re: Adding AC??
it shouldnt be too bad. i am in the process of adding factory a/c in a truck that didnt come with a/c.
you will need the brackets for the compressor and a new power steering pulley with 2 slots in it, you will need the outer box and inner box, as well as heater hoses and all the a/c plumbing and components
every thing should bolt in except the box itself
the a/c box requires a hole like this:
http://i178.photobucket.com/albums/w...r/P1070020.jpg
i made a template off the donor truck that i will put on the other trucks firewall, it will make cutting a lot easier
http://i178.photobucket.com/albums/w...r/P1070022.jpg
The truck should be done within a month
heres the build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=383629
2badgn 02-02-2010 09:05 AM
Re: Adding AC??
I know that some companies- i think Brothers - sell a complete AC kit. Dont know how easy it is but there r 2 routes that can be taken when adding AC. THe first route is to find all the pieces from a donor AC truck- and there r ALOT of pieces- compressor, condensor, AC lines, drier/receiver, correct AC blower, AC style inner glovebox, AC vents and AC dash/trim, AC/heat controls, evaporator, wiring harness, etc.
This is ALOT work. It might be worth it to purchase a complete AC kit bc u can use your non-AC controls and air vent.
I might convert in a few years but the kit costs $1300.
old Rusty C10 02-02-2010 11:34 AM
Re: Adding AC??
i have found all the parts cheap enough i just have to install them im into it for about three hundred now my truck came with AC originally that someone ripped out but even with a non ac cab it was easy enough to put the AC parts in it i did that back in 03 on my 86
87Bob 02-02-2010 12:09 PM
Re: Adding AC??
Would you like to sell a copy of your template?
95 S_Trucker 02-03-2010 01:38 PM
Re: Adding AC??
i dont know about that, its nothing special, just a piece of cardboard with some holes in it. ill do a detailed drawing of it and take some measurements and i will post it in here then.
BGRAFX 02-03-2010 01:52 PM
Re: Adding AC??
Thanks guys for the responses. I passed on all 3 trucks but still looking for my next project. That template will come in very handy for many future members projects so please keep us updated.
JohnC 02-03-2010 03:13 PM
Re: Adding AC??
You could also go with a vintage air system or something like that too. Keeps the firewall clean, and you get A/C
