4x4 lift kit 4"
2 Attachment(s)
Have a 4x4 lift kit with blocks. Complete less shocks.
All clamps etc. May even have poly bushings taken off new set for your installation. Do not want to ship too heavy. $ 150.00 |
Re: 4x4 lift kit 4"
ttt
Re: 4x4 lift kit 4"
Are those rear springs standard?They look arched.Are they included?
Re: 4x4 lift kit 4"
Yes, the front and rear springs in the photo are part of the package.
Now that you mention it, I should measure the arch. Those could be a 2-4 inch lift. The rear spring plates are junk, you will need to find some new ones. The blocks are 4". Heavy duty compared to the Tuff Country I bought, but I wanted a really soft ride. The truck is on my project build with those springs and blocks under it. http://67-72chevytrucks.com/vboard/s...=1#post2826812 |
Re: 4x4 lift kit 4"
ttt
Re: 4x4 lift kit 4"
if tim passes, would you sell and ship just the front springs?
thanks! Josh |
Re: 4x4 lift kit 4"
Let me consider it.
I need to measure the arch, and I want to get this stuff out of my building for the next project. Will advise. |
Re: 4x4 lift kit 4"
The arch on these springs is Front 4", Rear 8".
So you can compare it to what you have. From eye centerline you can subtract 1". Mike |
Re: 4x4 lift kit 4"
ill measure my truck and see-- right now i have 2" springs, with a 1" add a leaf, and a 1" zero rate in the front, and a 3" block in the rear.
Re: 4x4 lift kit 4"
ttt
Re: 4x4 lift kit 4"
do you still have them?
Re: 4x4 lift kit 4"
Yep!
Re: 4x4 lift kit 4"
ttt
Re: 4x4 lift kit 4"
If you will ship the front springs, rear blocks and hardware I'll take them (if shipping is not outrageous). Figure shipping to a business address in Florence, AL 35630. Thanks,
Joshua |
Re: 4x4 lift kit 4"
Bump for an awesome deal. A wire wheel and some paint and they'll be as good as new.
Re: 4x4 lift kit 4"
JQ-71: Let me send you the arch measurements they may be 6".
I think the freight is about $ 150.00 UPS, motor freight would be less, and I may have a big enough box and pallett. Will advise. |
Re: 4x4 lift kit 4"
I could use the front and rear U bolts with new bushings, if it gets split up. May fit in a large USPS flat rate $12.00 box.
Re: 4x4 lift kit 4"
Sorry, do not want to break this up
