Flip Kit Questions.
.Is C-Notching a frame necessary when doing a flip kit? Can it be avoided?
Thanks alot in advance. |
Re: Flip Kit Questions.
if you carry loads, yes. you will have to remove the bump stops and their mounts
also the amount of leaf springs you have.i have 4 and i got a good 6inches between the axle and the bumpstop
I would use a notch, I hate bottoming out. my 2 cents
i hauled around a 36" walk behind lawn mower in mine and all i did was cut the bump stops/mounts off never hits
That looks like a good amount of room. As was stated, a big factor of clearance has to do with the # your leaf pack as well.
Thing is though, atleast with my truck, that clearance is sufficient for an empty bed or hauling around a motorcycle and gear. Every now and then though, atleast with me, something comes up and I have to haul a yard of mulch or something. That's when I don't want a suspension modification not allowing me to use my truck as a truck. So, if I do decide to go with a flip kit instead of shackles/hangers, I will install a small C-Notch. |
motocross:also how do you like the heavyer front sway bar? notice any thing
im thinking of putting a 3/4 ton one my truck |
ok guys thanks alot.
i think i would rather do shackles and hangers to drop it 4" because 5" seems like too much for me but im not sure until i get the wheels. i will be running 20"s. thanks for your input. |
how tall of wheel and tire set up?
im not sure yet. will probably be boss 338's or similar in 20". not sure of tire. probably 45 all the way around
You will likely regret a shackle/hanger drop. S/H drops really don't allow you to lower it more unless you want to install drop leafs, or take out the S/H all together and go with a flip. Just about everyone who does a S/H drop usually want to go lower once installed...including myself. Do a flip, and be done with it. If you want more, then install drop shackles.
x2
go big or go home |
if necessary, is there anyway to add height after the flip?
add a leaf or put in a helper air bag
do a flip kit, you wont regret it
i want to rear fenders slightly above or level with the very top of the tire. I guess its one of those things where you just have to buy the wheels and tires and see where to go from there.
thanks |
is that with a 5" flip? how tall would you say your tires are?
roughly 27" tall.
mine are 28in high.the first pic has a bunch of weight in the back so it sits a little lower
http://i47.tinypic.com/1060vhs.jpg as you can see the crap in the back(and the pos elco:lol:) http://i45.tinypic.com/w2gdax.jpg |
