HELP 700r4
alight ive had it with my roommates 1986 k5 with a 305 700r4 hopefully some one could help me out
first it wouldnt shift to 3rd gear we found out it was due to a falty TV cable it was melted so we changed it out with a new one got that all replaced and at first it wouldnt adjust the valve was sticking so we got it free some debre was making it stick got all that fixed also noticed the valve body spring (orange one) was broken replaced that also took a while to find one but got everything back together now it shifts up fine goes threw all gears good with no hesitation but as soon as you get into 3rd or 4th and you let off the throttle at all and accelerate again it will just rev like its in nuetral but once its back in 1st you can acceletrate again to what ever speed so basicly its not down shifting after 3rd gear and wont upshift intill its in 1st again ive adjusted the tv cable twice now and its still doing it she only works like a 1/4 mile away so it works to get there and back lol inless you need it to down shift by the way i have taken the gov out the gear looks fine no broken grooves or anything did notice it had 2 different springs on it though one was a soft spring and the other was a little stiffer |
Re: HELP 700r4
have you tried to manually downshift it with the shifter...it may help to downshift the truck until you can find out what's wrong with it...I don't have any knowledge to answer your question though...I have a 700r4 behind my diesel and it's a mystery to me...lol
Re: HELP 700r4
Whats the fluid look like? Is there trash in the pan? A bad tv cable will cook a 700r4 in a hurry. Probably not what you want to hear. Sounds to me like 3rd gear is burnt up as well as overdrive. Driving such a short distance is going to hide a lot of issues.
Re: HELP 700r4
the fluid is a little burnt no trash or metal in the pan wat so ever
weve changed it at least 6 times with new fluid every time by the way we are driving it in over drive regular drive starts off real slow so she doesnt use it its P-R-N-Od-D-1-2 i need it fixed not just down shifting with the shifter |
Re: HELP 700r4
If the fluid has been changed and is still burnt. Start taking it apart. you need a tranny. 700r4's wont live more than a few miles without the tv cable functioning properly.
Re: HELP 700r4
ok she doesnt have the money for a new one but what would be wrong with the OLD one the whole trany just doesnt burn up what specificly in the trany would be messed up
Re: HELP 700r4
It doesnt work that way with an auto trans. if one clutch pack is burned up the whole trans needs rebuilt. at a minimum new clutches/steels and a paper and rubber kit. the trash tears up the seals/clutches in the whole tranny when one clutch pack goes. a rebuild is in order.
Re: HELP 700r4
I know thats not what you want to hear but on the upside. theres countless numbers of 4wd gms that used the 700r4. a used tranny is a decent option if you can find one in good shape.
Re: HELP 700r4
Re: HELP 700r4
Sounds like it is going to need a rebuild/replacement. My 700r4 was working flawlessly after a corvette servo install. After I decided to do some "preventative maintaince" by changing filter/fluid, I experienced issues. 2nd slips on uphills, 3rd always acts wierd, revs up for about a second and then shifts. It's been doing this for a long time now since it first occurred.
You may want to try that lucas additive. I used it in mine recently and it helped firm up the shifts a bit, buying me more time until I get it rebuilt. |
