Electric Cooling Fan Install...
Hey guys,
THought I would toss some pics of my cooling fan install your way. Just remember the Blazer is a daily driver, and it has been cold here.. with more snow and sloppy roads than in the last 20 years ! I ordered my fan controller from http://www.dccontrol.com/fancontrol.htm . It cost me $88.95 including shipping. Here is what I got ; http://pic20.picturetrail.com/VOL159.../382927931.jpg http://pic20.picturetrail.com/VOL159.../382927936.jpg Everything looked great. The only thing I wondered about was the fact that the relays are sitting in eboxy, not a socket - so you can't change a relay if is goes bad. But the designer may have a good reason for this.. THis controller is designed for a 3.8L two speed taurus fan. I initially mounted the controller to the shroud, thinking I would save wire and keep things less cluttered (always a challenge for me ;-)). But I thought I would be better off keeping it away from the heat of a radiator. So I moved it to the inner fender. http://pic20.picturetrail.com/VOL159.../382927962.jpg http://pic20.picturetrail.com/VOL159.../382927980.jpg Mounting the fan to the radiator worked out well as you can see it lines right up with the support. 3 screws hold it to the top radiator brace. I will add conduit later this spring when things warm up outside. !! http://pic20.picturetrail.com/VOL159.../382927991.jpg http://pic20.picturetrail.com/VOL159.../382927923.jpg THe temp sensor pushes into the radiator between the cores and works really great. It was very easy to install. So far it is working great ! I will fab a lower bracket this spring when I add a serp belt set-up. and MAN !! flash photos make my truck look like ass !! It really isn't that dirty in real life... or am I just used to it ?? LOL !! |
Re: Electric Cooling Fan Install...
So does it run the fan at two speeds still?
Kicks it on high only when needed? Great easy 'how too', thanks for posting. |
Do you think the fan will move enough air to keep it kool??
Having a shroud would be more efficient but as for the fan, it'll move enough CFM's for sure. |
very Kool
what year taurus?? I'm getting ready to move into my engine bay to clean somethings up this looks like a simple mod that will free up a couple ponies too!! Thanx Jeff |
Also, what size fuses did you use for your connections? I have this fan in my S-10 and the kit I have now only operates the low speed fan, and it turns out this isn't good enough for A/C on in traffic when it's 90 or above out, which is most of the summer, I really need the high speed, but my S-10 has a 195 thermostat, I don't want the fan running while going down the highway too. |
Sounds like a great mod to do for sure. |
Does anyone have the thickness of these fans? We have clearance issues on our bb serpentine setup.
I put an inline 30 amp fuse and I am hoping that will be enough. So far, it has been fine for the week I have driven it and it has run quite often in Drive thrus and such. I suppose that it may draw a little more when summer gets here and things get really hot, but I think it will be fine. I can always step it up if need be. |
I just went out and tried to get you a measurement... as it is mounted now from the radiator core to the back of the motor is about 5.5 inches.. that is not exact, but close.. |
Thanks!
And yes, these fans pull some serious air... the only reason I haven't hooked up the high speed in my S-10 is because they also draw serious amps too!!! I've read the high speed can draw up to 50amps on start-up. S-10 4bangers are finiky with heat, it's easy to overheat one, which is why I really need the high speed. It's great to finally find a kit that adresses the high speed fan "problem." Most people only run the low speed or high speed only. I'll have to order this when I get my taxes back, then I can use the kit in my S-10 to hook up the "Jeep" fan I got for my 67 :D |
Thanks for the info, I've been wanting to switch to an efan. I went to the boneyard today and found one out of a '94 Taurus with a 3.8 for $30.
I am certain that these fans pull the most amps when they are very first starting to spin. When testing my fan to make sure it was a working unit (it was used after all) I could tell a big difference in what it pulled from a dead stop, high versus low. I even thought to myself that the high side was gonna need a bigger fuse! However, the way this is set up, high only comes on after low is already running and spinning the motor. THis definatley lowers the amp spike to what at this point has been less than 30 amps. (been on a couple of weeks and no blown fuses). I wish I had an inductive pick up for my Fluke meter, I would like to know amp draw at speed on these fans.. maybe I can borrow one ! I realize there may be certain times that the engine is hot already and I start it, possibly resulting in a high speed start... but I wired mine to run even with the key off and the odds are low.. Time will tell when summer gets here and puts a real world strain on the system. SOmeone may have already tested this sytem out and they mave have some real numbers.. If it only spikes around 50 on initial run-up, I will just up my fuse size... Take this as food for thought for your upcoming fan project.. not really dead on factual instructions.. :pty: I really like discussing these types of things..;) Good luck on your truck and keep us posted ! |
almost all the fans I have seen run a relay to handle the power draw
what happens if you wire both together??? |
Thanks for posting the pics and write-up. I got my hands on a fan out of a 05 mustang GT a couple of years ago and was planning on doing something similar. That fan controler is just what I need. Sweet work dude. Later.
That's what I have been reading, there's only a big spike when the high speed turns on by itself. I found another kit that will run the high speed only, it regulates the speed of it, starting it off slow, and ramping it up as more cooling is needed, but when actually running, it uses less than 30 amps. If the low speed is already running, and it switches to high speed, I don't think it would have a large amp spike, because the fan is already running.
I like the idea of this kit better. There are wiring diagrams out there on how to do this yourself (have both fans working) but this is definitely not my strong point. Kinda scared of wiring :lol: |
the most important part of cooling is the shroud....I wouldn't split them up...the taurus fan is a better fit pulling air though 90% of the rad another reason for the 2 speed fan is if you ( like I have) is A/C you need to pull air across the core in traffic when you need the A/C the most..the kit I did on my buddies truck had a seperate wire for vechicals that turned it on when the A/C was turned on...I think the kits with thermostats are probably best..they work and are pretty simple to hook up and come with all the right size wires and what not..Also they are adjustable for on and off temps
