-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   Difference between coils and blocks? (https://67-72chevytrucks.com/vboard/showthread.php?t=387376)
72gmcshorty 02-17-2010 08:45 PM
I am wanting to lower the back of my truck about 6". I know there are drop coils and drop coils plus blocks. Whats the difference between using just coils and coils plus blocks?
SCOTI 02-18-2010 01:38 AM
Re: Difference between coils and blocks?
4" coils plus blocks allow running a standard length shock w/factory brackets. 6" drop coils alone are going to be too much drop & will typically require other mods: modifying the OE shock brackets; using 'drop' shocks; or replacing the OE brackets w/a shock relocator kit.
Of the trucks I've ridden in, 4" coils w/blocks rode better vs. 6" coils. They weren't 'apples to apples' set-ups (different manufacturer springs & shocks) so it's just a subjective opinion.
sv10001975 02-20-2010 07:54 PM
there are also so other advantages to using the blocks, but I have heard that the 4" spring and 2" block can cause some problems on a 15" wheel. you also get the advantage of keeping you instant center of you suspension in a better location vs. the 6" lowering spring. i have 6" springs and will changing to 4" springs very shortly. all i am waiting on is trying to confirm the 2" block and 15" wheel interference issue.
SCOTI 02-20-2010 08:30 PM
The 'interference' issue w/2" blocks is the bottom edge of the shock mount & u-bolts are just past the scrub line of the wheel. In the event of tire failure @ speed, there is a possibility of the mount or bolt contacting the road which can lead to loss of control.
1.5" blocks work w/15" wheels.
sv10001975 02-20-2010 09:23 PM
do you happen to know the length u bolt needed for the 1.5" blocks? this way I can go ahead order the bolts while I make my blocks.
SCOTI 02-21-2010 04:17 AM
I can go measure just as easily as you can. Put a tape to your current ones & add 1.5". Done....
If there's some reason you cant measure yours, let us know.
72gmcshorty 02-22-2010 07:29 PM
would 5" spring and 1" block have any issues?
N2TRUX 02-22-2010 08:42 PM
They might not have an issues, but I have found the more drop you can gain from "static" changes the better off you are. Ok, let throw a disclaimer and say in "most" cases.
What that means is try for the best option other than spring drop. Anything more than a 2" spring up front and a 4" spring in the rear and the ride quality starts to degrade.
robzilla 02-22-2010 08:51 PM
does anyone have some pictures of the setup? i'm looking to do the same with blocks and coils.
thanks
