-   -   71/72 throttle linkage (https://67-72chevytrucks.com/vboard/showthread.php?t=388678)
lts70 02-24-2010 04:12 PM
I bought a gas pedal conversion plate from LFD to switch over my 70 gas pedal to the 71/72 set up. I have found the pedal assembly but do not have the cable that hooks it up to the carb linkage. Does anyone have a Napa part number for this or is it a LMC item?
Also it is missing the stainless steel surround. Can you still get those?
gcburdic 02-24-2010 04:27 PM
Re: 71/72 throttle linkage
might want to order up the lokar cable setup...seen a couple guys do this and it looks good....check with member 'sinister' and 'hart rod' they both have done a little write up on it too...I'll see if I can find the thread
BLACK AND BLUE 67-72 02-24-2010 04:32 PM
610-1417 24" LONG
610-1426 21.375" LONG
Both are Napa Numbers. ;)
lts70 02-24-2010 07:19 PM
I have a Edelbrock 650 performer carb. Do you think I will need the 24" or 21.375" long cable?
I tried seaching for the lokar linkage but had no luck. I bet the look good.
Sinister 02-24-2010 07:36 PM
The Lokar stuff is spendy, but I had to go with it because I had a Lokar kickdown setup already . Here's a link with pics: http://67-72chevytrucks.com/vboard/s....php?p=3810086
lts70 02-25-2010 10:47 AM
Do I need to buy anything besides the cable to run the stock cable set up? Like any brackets that bolt to the manifold to hold the cable from moving? I still can’t find any info on what length I need as well. Any help would be appreciated.
Sinister 02-25-2010 11:08 AM
You'll need a carb bracket. Don't know if those lengths listed are housing or cable lengths. Can't help there. It'll depend on your setup, intake, carb, motor location. The nice thing about the Lokar setup is it's custom fit and adjustable. I used a 24" Lokar cable and had to cut it down to size. Good luck.
Hart_Rod 02-25-2010 12:01 PM
I've got an extra cable I'll send to you for $10. LMK
Camaro_nut2001 02-25-2010 12:52 PM
Hello Hart_Rod, if he doesn't want or need the cable I could use it on my upgrade that i'm doing. Thank you
Hart_Rod 02-25-2010 01:17 PM
I've got 2 of them.
lts70 02-26-2010 02:17 PM
Does that include the carb bracket and shipping?
Hart_Rod 02-26-2010 02:23 PM
No carb bracket. Add a couple $ for shipping.
72K20 02-26-2010 04:20 PM
I'll take the other one if it's still available? Moved my engine forward when I put in the 700R4 and have been goofing with throttle cables ever since.
