-   The 1967-1972 Chevrolet & GMC Pickups Parts Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=8)
-   -   CA Original TRUCK TILT FOR SALE (https://67-72chevytrucks.com/vboard/showthread.php?t=389340)
GABE310 02-28-2010 12:11 AM
3 Attachment(s)
I'M SELLING A CHEVY TRUCK TILT(not van) OUT OF A 71 TRUCK IN GOOD CONDITION. STEERING WHEEL NOT INCLUDED. THE TILT IS NICE AND TIGHT. HAS SHIFTER, BLINKER AND TILT LEVERS.(see pics). $300 shipped or trade for original under dash 8track
budnikguy 02-28-2010 01:04 PM
Re: Original TRUCK TILT FOR SALE
interested, where you located in SoCal?
too much stuff 02-28-2010 01:42 PM
Are you sure that is from a pickup? Doesn't look quite right to me.
6872xtc 02-28-2010 01:43 PM
Put me second in line please, Dave
lks dcvn 02-28-2010 03:18 PM
looks like a van tilt to me due to the wiring harness connection [straight] - the truck ones were half moon shaped.
wancosc356 02-28-2010 03:52 PM
I would have to agree with too much stuff and lksdcvn. It does look like a van tilt. Based on the tilt lever knob, hazard knob and wiring connector. I also don't see a neutral safety switch. How long is the column housing?
Just an observation. Don't hold me to it. Just trying to help.
Classic Bowties 02-28-2010 04:47 PM
2 Attachment(s)
Bad info there guys, you can't go by that given the fact that it may have had the T/S switch replaced at some point. Unless really old GM stock (pre 78-9'ish) all GM/Delco replacement switches have the flat plug and jumper adapter like pictured below. I am not saying this one is or is not a true truck tilt as there are several other ways to confirm that for sure, am only stating that you can not go by the info quoted above. Mel :chevy:
70LonghornCST 02-28-2010 04:54 PM
The end spline looks to be the correct truck length to me. I had a van tilt that I purchased off of ebay before I knew there was a difference...they are much longer. This one in this thread matches the correct truck tilt that I have now (purchased after I realized the difference) with a short spline. Just an observation.
GABE310 02-28-2010 05:42 PM
3 Attachment(s)
It is a truck tilt
I also have a van tilt TAKE A LOOK AT THE DIFFERENCE IN THE SHAFTS!
THE TRUCK HAD THE SHORTER SHAFT AT THE BOTTOM.
72k5zl1 02-28-2010 07:43 PM
is it sold? i am new here and dont know how things work yet. i sent pm hours ago. if you still have let me know. thanks
