-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   McGaughy 4/6 install on 05' (https://67-72chevytrucks.com/vboard/showthread.php?t=389493)
DWC 02-28-2010 10:32 PM
I have an 05' Silverado shortbed that is my daily driver. I bought a Mcgaughys 4/6 drop kit and was wondering if anybody had any tips or advice about installing this kit. I have installed a Belltech 4/6 on my old 89' shortbed, but that was back in 89'. Did that one in a weekend, am I looking at the same time or longer? The instructions make it sound pretty straight forward but I'm sure if you've done it before you have some advice.
Thanks, Dave
Inverter 03-01-2010 04:31 AM
Re: McGaughy 4/6 install on 05'
Dave,
I did a 3/5 on my '04. My install used an aluminum block in the BJ pocket (to b used w/oem wheels)so drilling out those rivets was a Pita. Don't know if you have that same spindle. Other than that, it wasn't bad at all.
The spindles on the 88-98s are much easier, not having the hub n all ,so the NBS's are more work.
~T.
