-   -   76 Custom Deluxe tranny swap.. (https://67-72chevytrucks.com/vboard/showthread.php?t=390239)
jmitch333 03-04-2010 05:47 PM
Hey guys, Im new to the forum and I could not find an answer to my specific question anywhere on this forum upon searching. I just bought my first truck, a 76 Chevy Custom Deluxe Longbed with the 250 straight six engine and 3 speed manual tranny (previous owner converted from the column to the floor). To my understanding, everything is stock. What I am wanting to do is swap out that manual tranny for an automatic tranny but I dont know what will work and what vehicles I could pull one off of that'll work with the 250 and what other parts I would need. Any suggestions?? Thanks in advance.
N2TRUX 03-05-2010 10:02 AM
Re: 76 Custom Deluxe tranny swap..
Welcome to the forum jmitch333. You should be able to put a TH350 or 700r4 behind your six. You can piece it together, or find a donor truck to get everything you need.
old Rusty C10 03-05-2010 11:23 AM
you could put a overdrive behind it but you would need to get the wiring for it too
leegrady 03-05-2010 09:55 PM
Some of the things to consider when making such a conversion is: other than the obvious,
Radiator will need to be changed with one with a trans cooler.
Rear end gear ratio varies between a manual and an automatic, and propeller shaft length.
Automatic overdrive trans. use computers, and sensors to operate shifts, and lockup converters.
Neutral safety switch.
Automatic transmission brake pedal, (it's larger).
I would recommend a thm350 or thm400, non-computer controlled.
