i need some original lowback buckets
i'm hunting for some '73 and up lowback bucket seats and console for silver. doesnt have to be perfect because i'm going to have them reconditioned anyways. thanks guys, Dennis
Re: i need some original lowback buckets
Too bad you are on the other side of the country. There is a guy selling the buckets and console out of a 77' Blazer for $ 100.00 on the Baltmore (MD) Craigslist
yeah i heard that. i've tried a couple people on cl in different states and they kind of trip out because im not local. and maybe because the desperation in my voice:lol:
Dennis, what is it exactly you are looking for? That is, will the lowback 1973 and up Blazer seats work for you? Do you need seat tracks, or just the seat frames?
i'm looking for everything buddy. everything from the mount tabs,(which i can get at u pull it)tracks, seats, and console.
I will keep my eye out for you bro. I am heading up to Pa. in a couple of weeks for my niece's birthday party. I have a couple of guys up there that I can check with. I know how hard it is to find these seats and consoles. I managed to get lucky with my Blazer since all of the original stuff was there.
I have set no console if you ever coming through North Mississippi
right on thanks guys! wonder how much it would cost to get those babies to california?
Greyhound them, it will be cheapest.
How exactly does that work?
This is taken directly from Greyhound.com. SIZE, WEIGHT AND VALUE LIMITATIONS Size: Packages will be accepted for transportation, provided the dimensions of the package are within 30 inches X 47 inches X 82 inches. Shipments of Skis and/or Ski Poles will not be subject to the size limitations specified herein. The Carriers participating in these rates, rules and regulations reserve the right to refuse to accept a package if its dimensions, even though within the limits specified herein, exceed the size or capacity of the Baggage and Express Compartments of the available vehicles. Weight: No single Package will be accepted for transportation that exceeds one hundred (100) pounds in Actual Weight. Provisions for shipments weighing up to, but not exceeding, one hundred fifty (150) pounds apply in selected areas. Shipments over one hundred (100) pounds are limited to the routes of carriers with a (150) after the name. See next page for applicable areas. Xpress Baggage shipments may not exceed 75 pounds per piece. Value: No single shipment (Prepaid, Collect, or C.O.D.) will be accepted for transportation that exceeds one thousand dollars ($1,000) in actual or released value. Released or declared value is the value agreed upon between the shipper and the carrier as evidenced by the uniform receipt given to the shipper by the carrier at the time of shipment or within a reasonable time thereafter or as agreed upon. With the exception of Xpress Baggage Service shipments, excess value charges will be assessed for any shipment with value greater than one hundred dollars ($100). Xpress Baggage Service shipments will be assessed excess value charges for any shipment with value greater than two hundred, fifty dollars ($250). |
huh...
yep, im in sacramento. give or take 20 minutes. |
So, does the recipient of the delivery have to be at the bus stop to take it off the bus or what? I have wondered this process for a while.
You just have to pick it up from the terminal. The packages are unloaded like the rest of the luggage, and by Greyhound staff.
do the factory lowbacks recline at all?
nope
