-   The 1973-1987 Chevrolet & GMC Pickups Parts Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=5)
-   -   NC Wanted: Power Steering Pump (https://67-72chevytrucks.com/vboard/showthread.php?t=391267)
85gmcguy 03-09-2010 10:47 PM
I'm looking for an earlier (not sure of year) power steering pump with the flare type pressure fitting. I actually only need the fitting, but I'll take a whole pump. Doesn't even have to work. Boy do I miss my U-pull-it!
Thanks!
lvschevytrucks 03-23-2010 09:32 PM
Re: Wanted: Power Steering Pump
Thanks!
Im sure I have what you need, do you have a picture.Ill get one tomorrow
DPowers 03-23-2010 10:36 PM
Local NAPA have it?
85gmcguy 03-31-2010 09:59 PM
http://67-72chevytrucks.com/vboard/p...pictureid=7154
http://67-72chevytrucks.com/vboard/p...pictureid=7153
The first pic is the fitting in the PS pump (reservoir removed)
Second pic is metric fitting/hose on the right, flare type hose on the left. I need a fitting for the flare style.
Thanks!
bigdnew 03-31-2010 10:04 PM
so did you find one.
85gmcguy 03-31-2010 10:07 PM
Not yet, still looking. Do you have a spare one?
bigdnew 03-31-2010 10:08 PM
i might, i have a '74 i'm parting out. i looked at the pics trying to look and see if we have a match
bigdnew 03-31-2010 10:15 PM
i have a rubber line hooked to return and a fitting that screws directly into the pump.
85gmcguy 04-01-2010 03:09 PM
The fitting that the pressure line screws into (on back of pump) is the one I need. Should be about a 1" hex. It shows in the linked pix. '74 should be the flare type (that I need) for sure.
Thanks!
bigdnew 04-02-2010 11:36 PM
I am hoping to pull the motor mon or tue.
85gmcguy 04-03-2010 12:29 AM
Cool! Keep me in mind.
