-   -   swap 64 gauges to 66 what is needed? (https://67-72chevytrucks.com/vboard/showthread.php?t=391406)
jsinor1956 03-10-2010 07:00 PM
I am changing 64 gauges with idiot lights to 66 gauges, with what is needed? I have wiring for both clusters. The plugs look the same, Do you just plug em in and thats it? Or what other wiring mods and parts are needed.
Jim
DPowers 03-10-2010 08:48 PM
Re: swap 64 gauges to 66 what is needed?
Plug n Play
daverod 03-10-2010 11:12 PM
You have to change the oil sender and the temp sender. The oil sender needs a line that will screw into the back of the gage. Temp sender is the one wire type. I did it but I'm still in the process of finishing it up.:waah: I'm pretty sure you can still use the wires that go to the temp gage you just use one and make sure you hook the same one to the gage. Any auto place has the oil pressure sender. I used the copper type, seemed to work ok. Leaked alittle at first because I never tightened it up good enough.
daverod 03-12-2010 12:04 AM
Rays chevy restoration site has a write up how to do it.
Vernski 03-12-2010 12:49 AM
Dave do you have a link to the write up thanks....Vernski:metal:
Slow Build 03-12-2010 12:54 AM
Quick question since we're on the subject of gauges. Other than the 5 screws on the front, what else needs to be done to get the gauges out? Found one at a junkyard and it wouldn't budge after removing the screws and I didn't want to stick my hands into the spiderwebs to feel around the back and didn't want to put my head on the gross carpet to be able to see the back.
daverod 03-12-2010 12:59 AM
I'm not sure how to do it just type it in on your search thing. It in the tech section.http://rmcavoy.freeshell.org/ Damn I'm good. Ok it was really easy.:lol: All this talk almost makes me want to finish mine. Maybe this weekend. The main reason I swapped was so I could put in a tech. Then I switched to a hei And I'm not sure how to hook it up.
protrash64 03-12-2010 01:05 AM
Also need to remove the speedo cable and the oil line going to the gauge. Probably some electric harness, too.
Slow Build 03-12-2010 01:14 AM
I figured that I could deal with that stuff once I pulled the gauges out of the dash a little, but with the screws out the gauges are still solidly held in the dash. I can't even pry them out a little bit with a screwdriver.
Sorry for the thread-jacking
protrash64 03-12-2010 01:23 AM
I wonder if it's rusted on??? I would think that it would have some give.
daverod 03-12-2010 01:37 AM
Next time take a BFH with you.:lol: I'm pretty sure just the screws hold it in. It comes out towards you.;)
Slow Build 03-12-2010 01:58 AM
I think part of my problem is the ignition switch. Not stock and I can't get it completely out (thread issues) but I can't really move the gauges enough for that to even be issue yet. Before the BFH comes out of my tool bag I'll have to resort to laying on the gross carpet and get a good look at the back.
Sorry for the interuption.
Now back to your previously scheduled thread.
EVBuilder 03-30-2010 11:11 PM
Slow build... there is a tach lead right on the side of distributor cap for that. It's even labeled "tach" if you can get in there to see it if not remove the cap and you will see it.
EVBuilder 03-30-2010 11:13 PM
Sorry wrong name it was daverod....
