tranny id tag
found a transmission ID tag on my automatic tranny. what does this tag tell? it's located on the passenger side just above the pan:
Turbo Hydramatic C J 73J 229 serial 73-CJ 6510 I should have counted the bolts while I was under the truck, and I could barely get under so I did NOT get a pic. any help, fellas? |
Re: tranny id tag
Sounds like its a 1973 th400, ill have to look and see what the CJ code is. Comes up as installed behind a 454 in a 1/2 3/4 or 1 ton chevy truck.
Re: tranny id tag
thank you,sir. I'll get a better look at it tonight when I get her up on ramps and can fit my wash-board abs underneath
| All times are GMT -4. The time now is 05:38 AM. |
