WTB column shift cable/linkage components
I just switched from a floor shifter to a column shifter and now Im in need of any other parts required to make it work. If you have something that will help me, let me know. Thanks
Re: WTB column shift cable/linkage components
What year and is it 2x or 4x??
Hmm, I have some 4x stuff, but that will do you no good.
Send tkorinek a PM on here. He should have everything you need. |
I have the shifter linckage from the column to trans. I will get a picture in a few.
Here , is this what your looking for? $10.00+shipping |
here is a th350 setup, I have one guy that I have to show it to, if he doesn't want it. Its $30 plus shipping, you can kind of see it on the top left
Maybe It,s a 3 on the tree!!!!! The mystery continues! HeHe.
2 Attachment(s)
linkage in first pic is not correct for 67/72.pic teeitup has is correct for 67/72 small blockAttachment 566342
Attachment 566343these are pics of correct bb linkage,frame pivot pin,linkage rod and linkage arm.shift lever that attaches to the trans is same for small and bb and is in teeitups pic.linkage rod for bb is longer and linkage arm has differant angle .trans sits a little farther back in frame with bb.I do not have linkage for sale only trying to help you get the right part.:chevy:4x4 frame pivot pin is same as bb I will have to check if 4x4 linkage rod and linkage arm are the same as bb I think so but have to lay them out together to make sure.I can check tomorrow,if so mosesburb might can help you out. |
Why don't you check out Kugel or Lokar. Mike's Bump and Grind Shop (mbgmike) is a vendor here and would be able to hook you up.
Soooo.... Teeitup, I think you have what Im looking for... Let me know if I can get it.
Thank you all for the info to help find what I need |
Well I sold this setup. I have another setup but am missing the small 'U shaped" piece that bolts to the tranny. $25 plus shipping for the rest. Thanks Randy
