anyone have any close up pics of powersteering hoses with DRopmember
Anyone running a Dropmember with factory powersteering pump , have any pics of the routing of your ps hoses, i got a premade hose kit from jegs..it just doesnt look like there is anyway to make it happen without serious modification to the powersteering bracket
Re: anyone have any close up pics of powersteering hoses with DRopmember
Not sure if this helps any. My engine is from a mid 80s pickup. Closest view of the ps hoses that I have in my photobucket. I got my hoses from JEGS also
http://i223.photobucket.com/albums/d...ec1ccc92a1.jpg |
looks like your pump sets up a lot higher than mine, mine sets right down on the lines
http://i300.photobucket.com/albums/n...0/DSC02188.jpg
They were a pain. I removed the pump from the block and hooked all the lines up then bolted back on but I had to make sure all the lines were in the right positions. |
has the back bracket on your powersteering pump been modified
Any way to run hard lines from the rack, to a remote location on the frame? (Maybe toward the front of the frame) And then run your flex line to that, instead of directly to the rack?
Just end the hardlines somewhere, that the flex lines will looks "nice",... not bunched up. I think the difference in P/S brackets depends on whether you have the long or short waterpump set-up. Bazooka has the long water pump brackets. |
what is a "flex line" ??
Check out billet specialties or Detroit speeds hose kits if you have issues with the jegs kit. They used a braided style hose that you can cut to length and put the hose ends on plus they come with the right rack fittings. They look a lot better and are easy to route. Whatever you do make sure you use a high pressure hose and hose ends on the pressure side , the return you can use whatever.
Come on guys we have complete braided p/s hose line kits with the correct rack fittings
and the fittings swivel as well.You can cut them to your length as you need them.They are braided lines retail is $140.00 for the set up and we will sell them for $120.00 and we have about 30 line kits in stock same day shipping.Support the Venders on the board! Justin www.scottshotrods.com |
thanks for everyones help, looks like i might need to give Scotts. a call
justin |
Not sure which brand that Jegs sales.... but we do offer a kit from Borgeson that works great. It is a universal kit (so certain applications may need to route the hoses a little differently). It has all the necessary fittings,is a rubber hose kit and runs $70. It's a great option for those not wanting to run the braided stainless. We have installed the kit on SBC and GEN3 motors without issues... it's the only rubber hose kit I will sell.
the problem might be that i am running a short water pump ! the ones i got from jegs have hydraulic style fittings on them and it makes them to big to make that kind of bend, i am also going to have to modify the back bracket on my ps pump.. Nathan did you ever come up with any pics of one with one of your hose kits on it that i could see??? my hoses are the same one on NASTYC10 truck
Power Steering Hose Kit Borgeson GM Self-Contained Pump to 1979-97 Mustang Rack Rubber Part Number # 153-925102 |
67cheby, did you ever get everything hooked up? I have had the same problem, and I have to run the rear bracket because some previous owner broke a bolt off in one of the mounting holes on the front of the block, and it WILL NOT come out. it has been fine with the one bolt up front and the bracket that hooks to the motor mount for a long time though, and I ordered new stuff for my powersteering yesterday, so Im putting it all in this weekend. I ordered a new rack (and getting rid of my autozone special) and also got the borgorson line kit. Just how are the hoses routed?
man they are tight, i bought a bracket from jegs that just goes on the back of the ps pump, but when i get it on it gives me the clearance i need for the lines but the factory alt belt hits the ps pump now.... dont know what i am going to do
I may have to modify mine to make it work.
How did you route the hoses? They make a 90 degree turn after they come out of the rack... so which way are they pointing? and what about the high pressure one coming out of the pump? If you can take a picture or two, that would be a HUGE help. |
i havent put mine on yet
We have said it in the past our rack fittings swivel once there are tight in the rack still
you can still swivel them around and this will make it easier for you guys in tight issues. They are $120.00 and in stock same day shipping.They are not rubber only braided s.s Sorry about that.For the price you cannot go wrong Justin |
