-   -   Where to get quadra jet rebuild kit? (https://67-72chevytrucks.com/vboard/showthread.php?t=400624)
Jobe72 05-03-2010 12:18 PM
Do you guys have a good source for a rebuild kit for our carbs?
Classic Heartbeat 05-03-2010 12:21 PM
Re: Where to get quadra jet rebuild kit?
You should be able to get a good kit at NAPA. However I would be sure to check the throttle shaft for play. If there is any play in it, I would send it out to a specialist to have it done because, the throttle housing will need to be drilled out and bushed. WES
Bears63 05-03-2010 12:22 PM
Yeah, the local NAPA store. Seriously, just go to a local parts store with the numbers off the carb and they will set you up with a rebuild kit.
John Pasinski 05-04-2010 03:55 AM
In my opinion.............Check out Cliff's High Performance in Ohio. I'd send the hyper link but I'm too inept at ths computer. I bought mine there. You can speak w/ Cliff, he's very good at what he does. ALL kits come w/ Ethanol safe parts. You can order them any way you prefer. They also come COMPLETE. Even new filters & filter springs.
Jim_PA 05-04-2010 07:49 AM
Cliff's is the best I've seen.
Most auto parts store rebuild kits include a few gaskets and a needle and seat.
joejbal 05-04-2010 07:55 AM
Also, check out the edelbrock kit that has different size jets, rods, hangers etc.
Jobe72 05-04-2010 09:51 AM
Thanks for the tips, I had found Cliff's on a search...thanks.
