door
got my new rocker put on but found out that when i welded in my patch panel for the lower part of the door i warped the front corner. does anyone know how to fix this?:waah:
Re: door
You could probably hamer and dolly it back out.
Re: door
the hole corner is pulled in too far and the bottom of the door doesnt sit flush with the rocker
Re: door
Got a pic?
You may have put a cut in the door, get if where you want, and reweld it. Do it on the truck if possible to make sure the door fits with the rocker and door opening |
Re: door
Re: door
it lines up good. so i have to cut my new panel off the door to try and straightin it back out
Re: door
i cant really mount the fender right now cause my truck is just a cab and a frame. its all takin apart with all the rusted stuff thrown away. so i have no core sopport right now
