-   -   Calipers will not fit on drop spindles... (https://67-72chevytrucks.com/vboard/showthread.php?t=402544)
silvereagle07 05-13-2010 08:07 PM
I'm finally getting around to putting on my DJM drop spindles and Performance online 1.25 rotor kit. No matter what I do I cannot get the rotors to turn after I install the calipers. I called Performance Online and they use the stock heavy half ton calipers and rotors. Anyone ever had a problem with DJM spindles not being machined correctly?
S10Fan 05-13-2010 08:36 PM
Re: Calipers will not fit on drop spindles...
Where are the rotors coming into contact with the calipers? Or is it "pad" pressure against the rotor?
joe231 05-13-2010 10:42 PM
Yeah, what s10fan asked....
Also do you have the correct calipers for the 1.25" rotors?
C10_86 05-13-2010 10:49 PM
If your pads are tight on the rotor, you need to compress the caliper before installing it on the new spindle just like you do when you put new pads in.
thrtsxchambers 05-13-2010 10:52 PM
x2
harnalien 05-13-2010 10:52 PM
I had this problem but it resolved itself after some driving. There is going to be some contact between the pad and rotor regardless. However getting the calipers to recess will help a lot.
silvereagle07 05-14-2010 07:42 AM
The rotors do not come in contact with the caliper, it's the outside pad pressure. The caliper(d52) is fully compressed and the inside pad is not touching the rotors. The outside pad is keeping the the rotor from turning without a tremendous amount of force. It looks to me like the spindle shaft (where the inside bearing rides) is not machined enough and causing the caliper to be off center. I have been to autozone to compare all the 1.25 calipers, pads and bearings are the same measurements as mine. I think I'm going to removed the bosses where the caliper slide pins mount to move the caliper closer to the outside of the spindle.
