-   -   Different fan shroud or cover (https://67-72chevytrucks.com/vboard/showthread.php?t=403657)
ddp 05-20-2010 12:48 PM
I have swapped my original 350 for a '92 TBI engine in my '71 Cheyenne. The new engine uses a longer water pump and the fan sits closer to the stock 4-row radiator, so my original fan shroud will not fit. I'm not so concerned about a shroud for cooling as much as a cover to prevent someone or something from hitting the fan from the top.
Does any one know of a stock application (6 cyl or different year) with a shallower shroud, or just a cover that mounts to the core support or radiator and extends out over the top of the fan?
Thanks.
extd56 05-20-2010 04:52 PM
Re: Different fan shroud or cover
I had to make one for the 1991 TBI motor in my 67
mclairmo 05-20-2010 05:13 PM
I believe the stock 6 cyl trucks came with a little finger guard that would work. Or, the aftermarket makes a cheapy chrome one that is a simple ring shaped piece that will work. Or, just make a simple flat one out of steel sheet that screws to the top of the radiator, not through the actual core, though.
ddp 05-25-2010 10:14 AM
Would anyone have a picture of a stock 6 cyl engine compartment showing the fan shroud or guard?
