wheel adaptors
hey guys i came across a set of 20 inch factory dodge rims i like the hell outa em but wonder if theres anyway i can get an adater to make em work on my truck i know the pattern is diffrent but wonder if i can get some kind of adapter to make em work....anyone ever done this?.....Steve
There is a company called Coyote enterprises that makes adapters.They start at 1" and go to 4" thick. You need to know what bolt patters. A lot of the custom wheel places have adapters you can order. The biggest problem is the 1" min. thickness
H2 Wheels
I found a set of take off Hummer H2 wheels for $200, they are 17" with a 8 bolt pattern. According to a local wheel/tire dealer they should fit. I have a 67 C20 with a 8 bolt wheel pattern. So if any of you know whether or not these wheels will fit, can you let me know. I know that the H2 is based on the Cheverolet 3500 frame and engine, so I am guessing that the wheels will fit. I am planning on putting on a set of low profile tires on these wheels to help drop the truck a little.:confused:
Hummer wheels should fit. I placed a set uf Hummer rims on my old longhorn once.
