-   -   1/2T long wb truck weight? (https://67-72chevytrucks.com/vboard/showthread.php?t=408868)
DBLSPRT68 06-23-2010 05:27 PM
Can someone tell me the weight of an 81-87 1/2T 2wd lwb truck? I need to know and don't have one "at the moment"! Will post pics later :metal:
Slofarmtruck 06-23-2010 07:10 PM
Re: 1/2T long wb truck weight?
My 84 C10 2wd LWB weighed in at 4500 lbs without me in it. Hope this helps.
hotrod_991 06-23-2010 08:09 PM
wrong year but my 77 wieghs in at 62xx she a heavy ole girl.
RandyP 06-23-2010 08:55 PM
You wanting the GVWR? 81 LWB is 6100.
Copytech 06-23-2010 09:08 PM
Really? My '84 C20 weighs 4200lbs full of fuel and me in it (190lbs).
RandyP 06-23-2010 09:10 PM
I gotta ask, how do you guys know what your truck actually weighs? I can barely find scales to weigh myself. :lol:
DBLSPRT68 06-23-2010 09:17 PM
Thanks guys, I'm wanting to know the weight of the truck itself. 4000-4500 sounds about right. That's what I was looking for. I'll be pulling "it" on a tow dolley if "it" will fit. I've got to get measurements, but I'll go to a JY to get that. Just wandering if "it" outweighed the tow vehicle. It doesn't! Did ya'll get that? Will post a pic in about two weeks when she's home. David
hotrod_991 06-24-2010 02:39 AM
haha hey man i just towed my 6200lb longbed 2wd from montana to souther TX on a uhaul car dolly loaded with a bed and other crap behind an 05 ford ranger 4x4 also loaded to the hilt. 1500 milesno issues sept horrible gas mileage. Also it will fit on the dolly the edge of the tire will just barely be to wide. It will strap down tho and be safe but FYI tho make sure you unlock the steering wheel cause the truck weighs to much for the dolly's wheel pad to pivot like it is supose to. good luck
DBLSPRT68 06-24-2010 04:04 AM
Thanks for that info. Does your truck have 7 inch wheels or 8's. I actually thought about finding some stock steel 7's (or van rallies) and old tires at the junkyard to put on the dolley side(front only). The truck has the wide 8's on it, so I'm thinkin I'll have to do this anyway. BTW, the truck I'm going to get is one of those extended cab's :metal:
Copytech 06-24-2010 07:12 AM
Buy some bulk dirt or gravel, you have to weigh in and out.
Slofarmtruck 06-24-2010 11:22 AM
I just went off what the scale said at the local dairy place!
hotrod_991 06-24-2010 11:46 AM
I have 7's in the front i would deff find just a crappy set or skinnies for the front so you dont have any issues
qu1cks1lver56 06-24-2010 01:12 PM
last time i was at the dump, with me in the truck my 86 was 4380 with about 6 gallons of fuel.
larrystone 06-24-2010 01:20 PM
My 1986 weights only 3900 pounds with the military front end guard which is 43 pounds.
DBLSPRT68 07-13-2010 11:20 PM
hotrod, you ain't kidding! Even with the junkyard skinnys on it; it just barely fit on the u-haul tow dolly! I didn't get a pic of it, thinking I might get a ticket or a lawsuit filed against me..... It just barely fit! No other issues with the 3 hour trip home. Here it is at his new home. Thanks for the help guys! David http://i6.photobucket.com/albums/y23...ewtruck002.jpg
westofb 07-14-2010 12:27 AM
Don't tell U Haul what you are towing or they won't rent the dolly. I have used their car trailers to haul these trucks, the long bed will fit with a few inches to spare and they tow very nice, I think it costs about $20 more than the dolly on local rentals, oneway rentals depends on where you get it and where you are taking it. If you go with the dolly, tell them its a s10 truck you are towing.
Never mind you got it home...should have read the whole thread before running my mouth!
DBLSPRT68 07-14-2010 01:23 AM
"tell them its a s10 truck you are towing" That's what I put down. 1985 s10 regular cab. I also got the $5000. insurance just in case..... I've used that before :metal:
SS Delux 07-14-2010 02:20 PM
Great looking truck ! I asume that is a custom job because to my knowledge they never made an extended cab silverado.
p_rubottom 07-14-2010 02:59 PM
Read up ;)
http://67-72chevytrucks.com/vboard/s...d.php?t=365878
motornut 07-14-2010 03:31 PM
cool truck,get weighed in and out when droppin scrap metal off,other yards should have scales too
78 Chevyrado 07-14-2010 05:27 PM
My 87 lwb silverado weighed around 4400lbs without me in it.
