-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   some help with my jimmy transmission... (https://67-72chevytrucks.com/vboard/showthread.php?t=409714)
masaki 06-29-2010 11:20 AM
4 Attachment(s)
Hi, I want some help with my jimmy tranny, I want to confirm the trasmission parts models in my jimmy, here are some pics:
please correct me if I'm wrong
Attachment 604993
Dana44
Attachment 604994
NP205
Attachment 604995
SM426
Attachment 604996
Umknown rear axle
The rear axle, is not the original, can somebody identify this part?, wich axle I need to buy in order to use the 4x4 option in my jimmy?
PS:
in other way, what mean married or divorcied transmission...=?
Redcap 06-29-2010 03:45 PM
Re: some help with my jimmy transmission...
That rear axle looks like a earlier Ford 9" or possibly a Mopar 8.75".
Your transmission should be a SM465 and your transfer case is indeed a NP205.
Married transfercases mean it attaches via adapter directly to the transmission. Divorced means there would be a short driveshaft between the output yoke on the transmission and the input yoke on the transfercase. A married setup is stronger.
propanemudtruck 06-29-2010 04:53 PM
Isn't that the muncie SM465?
Redcap 06-29-2010 04:57 PM
Yup, sure is. I had too many things going and typed the wrong thing.
raycow 06-29-2010 07:10 PM
Of US rears, Mopar, Olds/Pontiac (till 64), and Ford (till 56) had round center sections and no removable cover. I think maybe Cadillac and Packard too. All except the Mopar are too scarce to consider seriously.
However, considering where the OP is located, I think he is more likely looking at a Nissan or Toyota rear.
Ray
masaki 07-04-2010 07:57 PM
4 Attachment(s)
Hi thanks for the reply! here you can see more shots of the rear axle, somebody can identify this axle? in other way, what axle I need to find to replace this? remember I want to use the 4x4 option of the truck...
Attachment 607147
Attachment 607148
Attachment 607149
Attachment 607150
Masaki
Walts_restoration 07-04-2010 08:21 PM
is that an eaton HO52?
Davetopay 07-04-2010 11:02 PM
Nope. If it was an HO52 the center would have a cover held on with bolts.
Doubt it is a Toyota rear with that much width and beef. Also, if it had come from a Land Cruiser it would have a passenger side offset to the pumpkin and a bolt on cover similar to the Eaton.
Nissan Patrol could be a real possibilty. Not likely to be a rover though.
bglad420 07-04-2010 11:06 PM
Did you drag that out of three feet of dirt?
Davetopay 07-04-2010 11:11 PM
The more I look at it, the more it looks like an old Mopar 8.75 axle.
The snout on the center section, the welds and the fill plug look Mopar to me.
http://3.bp.blogspot.com/_5wtf5BICBh...0/DSC06273.JPG
raycow 07-05-2010 05:27 PM
I agree, it does look like a Mopar, but I just wasn't expecting to see one in Peru. The Nissan or Toyota rears I was thinking about are from the 2WD trucks, not 4WD. They have round welded covers.
How about giving us a little bit of help, like what is the wheel bolt pattern? Or maybe just a pic of the axle end with the hubcap off?
Ray
Blazer1970 07-06-2010 05:57 AM
What lug pattern is on those axles? I suspect that front and rear both came from a different truck. Probably a Dodge. Is it five lug?
