Lifting engine
I need to change the Oil pan gasket on my 350, I everyone I've talked to said I'll need to lift the engine a few inches. So don't have a hoist, but I got a front end loader on my tractor, anyway where and how do I connect the chains to the motor? Thanks Yall!
Re: Lifting engine
Sometimes there are lifting rings mounted with the intake bolts. Or you could just put a bolt thru the end of the chain into the front of the heads.
Re: Lifting engine
Can you jack it up? Maybe try to drop the pan with the crank spun up in the front first?
Re: Lifting engine
Is this what you were talking about? there is one just like it on the opposite corner of the intake manifold.
http://sphotos.ak.fbcdn.net/hphotos-..._6142200_n.jpg |
Re: Lifting engine
Re: Lifting engine
edit: just be carefull not to lift too far and break wires and stuff. |
Re: Lifting engine
Re: Lifting engine
You shouldn't need to disconnect the tranny, unless the engine will not go high enough.
Re: Lifting engine
When I changed mine (IIRC), I just unbolted the motor mounts, used a floor jack to raise the engine up a couple of inches and then slid a 2x4 block in between the mounts and the motor. Worked well - just another way of doing it I guess.
Re: Lifting engine
Re: Lifting engine
Re: Lifting engine
I had a friend jack up both the oil pan and transmission pan at the same time (with 2x4s between jack and pans) then slide pieces of 2x4 in motor mount spot . He had to loosen tranny mount bolts and of course motor mounts. Hoses won't be disturbed with the 2-3' inches of lift. |
Re: Lifting engine
Don't forget to disconnect the throttle cable.
Re: Lifting engine
...and make sure the distributer doesn't smash against the firewall
Re: Lifting engine
