-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   Dropmember & Manual Trans, z-bar ? (https://67-72chevytrucks.com/vboard/showthread.php?t=411152)
Wild83C10 07-09-2010 09:40 AM
Anyone running a manual trans with a dropmember? If so what did you do with the z-bar and the push rod from the pedal?
jasonb72 07-09-2010 10:58 PM
Re: Dropmember & Manual Trans, z-bar ?
I will be running a TKO600, but I am putting in a hydraulic clutch, so no issues.
PBFAB.COM 07-10-2010 01:42 AM
We installed a Dropmember and a manual trans a while back (with the z-bar). We ended up modifying the bracket where it attached to the frame, along with a couple minor mods on the pedal linkage. Wasn't too bad.
Wild83C10 07-10-2010 08:45 AM
Do you remember what mods you made to the pedal linkage?
PBFAB.COM 07-10-2010 10:50 AM
We had to modify thy linkage piece where it passed through the firewall. I don't recall exactly what I had to do, but recall that it wasn't a very difficult task.
Wild83C10 07-10-2010 10:12 PM
For future reference in case anyone else has the same issue. I bent the bottom of the rod (15*ish angle?) and put a little notch in the firewall so that the rod sits up a bit higher.
I also had to move the z-bar up off the frame an inch at the same time it was relocated so that is lined up with the pivot ball on the bellhousing.
