-   The 99-06 GMT800 Chevy and GMC Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=58)
-   -   '02 rear A/C drain location/cleaning a clogged one? (https://67-72chevytrucks.com/vboard/showthread.php?t=411178)
DGulliver 07-09-2010 04:05 PM
My '02 Suburban Z-71 is getting water in the rear, right behind the third-row seat, passenger side. The carpet's wet there, and I'm guessing it's the rear a/c condenser drain clogged. Anybody had one apart to clean it out? I can't seem to find where it's supposed to drain under the car..?
clinebarger 07-09-2010 06:57 PM
Re: '02 rear A/C drain location/cleaning a clogged one?
The drain is located behind the right rear tire there will be a rubber tube sticking through the floor next to the A/C & heater core connections.
Take it to the car wash first, And clean that area under the truck (its no fun having dirt drop in your face while your under there)
Take rubber tube off the drain & see if its clogged at the end were it necks down
DGulliver 07-09-2010 06:58 PM
Thanks, Cline- worked like a charm!
