-   -   Front Drop (https://67-72chevytrucks.com/vboard/showthread.php?t=41133)
Bigtyme 02-18-2003 06:11 PM
Front Drop
I put in 3" drop spindles and 2" drop spings in the front of my
82 swb GMC for some reason the right side in a little lower than the left side with a hint of negative camber. Would a front end alignment solve the difference in height.
Thanks,
Martin :gmc:
low 84 02-18-2003 06:19 PM
the alignment is just going to correct your camber. it will still be lower on one side. that is a common problem whne droping trucks. my passenger side is about 1/2 lower.
how much lower is it on one side?
Low87 02-18-2003 06:21 PM
Interesting, I don't have this problem. Seems like the problem would be in the springs, but if they're new I don't see why.
Tom 02-18-2003 07:22 PM
One side seems to be a little lower then the other on my 79 now that I put the 3" spindles on. I had the 2" springs on for some time and it was even. Im thinking maybe the springs arent sitting correctly in the perches when I put everything back together.
swervin ervin 02-18-2003 07:24 PM
Mine's about a 1/4" or so off. There are a lot of things that can cause this. After driving awhile, it will probably settle and level out a little more. One thing I noticed, which you proabably all have, if one tank is full, and the other empty, it will be off. Fill up both tanks and check it.
Bigtyme 02-18-2003 07:26 PM
Spindle Defects
I was once told that dropped spindles can be shorter than one another......whether it's true I don't know
Tom 02-18-2003 07:38 PM
Re: Spindle Defects
Sure they can, if quality control sucks where they are made. But then all spindles would come out that way, and the company would get a flood of complaints.
RockHQ 02-18-2003 08:00 PM
I'm curious to know if anyone's tested how the weight actually is distributed over the wheels on a fairly stock truck, ie. put scales under each wheel and written the results down?
-Axle
Captkaos 02-18-2003 08:38 PM
I am when mine gets closer to being an actual truck... ZIP IT MIKE!!!!
apstguy 02-18-2003 09:29 PM
-Axle
The sticker for the weight has the front & rear but not all four wheels. I'm assuming it is 50/50 with both gas tanks full and no cargo from FL to FR or BL to BR.
swervin ervin 02-18-2003 09:40 PM
I wasn't going to say anything. :D You act just like you know me or something.
RockHQ 02-18-2003 10:57 PM
Don't trust stickers. It can be a far cry from 50/50, easily. But as soon as i get my truck back into a drivable condition i'll see if i can measure the exact weight distribution (truck weighs 2480kg or 5460lb according to my VSR = vehicle specific registry)
apstguy 02-18-2003 11:15 PM
I didn't say that very clearly, Let me try again!
I think that the weight distribution on the rear axle is 50/50 from the right side to the left. Vice versa for the front two tires. The split from front to rear is NOT even close to 50/50.
solidaxel 02-19-2003 12:04 AM
I'll be waiting to hear the weight of each front wheel, as mine is 3/4" lower on the pass. side measured from the center of the wheel well to the pavement. Thought about a 1/4" donut under the front right spring, but am still thinking about it !!!!
Low87 02-19-2003 02:44 PM
My name's Greg, so...................When is that going to be??
RockHQ 02-19-2003 03:50 PM
Actually, you said it quite clear the first time and i understood you completely, but i still say the weight distribution for example on the rear axle from left to right might not be an even 50/50. How close, i don't know. It could be only a few lbs off, or a lot more. Anyway, hope we'll find out.
c10scotty 02-19-2003 06:10 PM
i have easy access to a scale guys if you wanna know i can do it. i have dual tanks and a 2.5/4 drop. only thing is that i have a big steel toolbox in the back...dont know how much it weighs. just holler and ill weigh each wheel seperately. oh, also remember that in 81 when they redid the front ends they lightened it a lot so that will change weight distribution.
Captkaos 02-19-2003 07:04 PM
In that case about the time you bag your truck.. (wonder how long that gives me......:D)
Low87 02-20-2003 11:00 AM
LMAO, you've got a good two years. :rolleyes:
Captkaos 02-20-2003 05:26 PM
That was WAY too easy..
