-   -   Tilt steering swap (https://67-72chevytrucks.com/vboard/showthread.php?t=414368)
tonypaul 07-31-2010 01:21 AM
Tilt steering swap
Has any one swaped in a tilt steering column from a newer truck? I want to have a cruise control stalk (engine swap) and would like to have my key in the column. I have already smoothed out all of the dash where the radio, heater/a-c, and the key cylinder hole already...
Thanks!
Thealien 07-31-2010 07:06 AM
Re: Tilt steering swap
Interested if you get some replies. It is probably doable?
Longhorn Man 07-31-2010 05:51 PM
you'll need to cut a larger hole in the bottom of the dash, figure out the ignition wires, highbeam switch wires, pipers if you go that new. Then the steering shft may need addressed too since it isn't the same as our trucks
