-   -   Got antifreeze on the floor. (https://67-72chevytrucks.com/vboard/showthread.php?t=415822)
blu-by-u-2 08-09-2010 06:08 PM
Whats up? Problem, changed carb from holley to edelbrock. Drove around the block and noticed antifreeze leaking by passenger door. Lifted carpet and found it leaking at heatercore.What caused this? never did this before. I dont use the heater or a/c could the two lines be bypassed. Oh by the way It's a 350 crate in a 77 2wd blazer.thanx for any 411.
camshaftgsxr 08-09-2010 06:12 PM
Re: Got antifreeze on the floor.
Yes you can bypass the hoses heater core is probably cracked just plug the holes in the intake and remove the hoses and heater box (might as well get rid of stuff you can't use any more)
Davidmichael 08-09-2010 08:09 PM
I think it's just a coincidence. your heater core let go just as you were working on the ride. :(
BigRed76 08-09-2010 08:12 PM
my heater core let go on me after swapping out valve covers :lol: made no sense to me but i just bypassed the heater core till i could put a new one in.
cableguy0 08-09-2010 08:43 PM
Once the heater core is old the connections become brittle. Just pushing on or moving a heater hose can break it. Its just bad luck
