-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   4" Black Diamond Suspension lift (https://67-72chevytrucks.com/vboard/showthread.php?t=41827)
'71k-10 02-23-2003 03:38 PM
I am considering installing a 4" lift on my '71. Black Diamond has a kits with rear leafs for 510 w/o shocks and a kit with blocks for 350. Has anyone had experiance with this lift or this company. Any info would be great. Thanks.
Super Chevy 02-23-2003 10:23 PM
not with the company, but if your looking on saving some money,mabe a just springs from them,then a shakle flip in back
S-C
Mudder 02-24-2003 12:20 AM
Check out the Tuff Country lifts.
'71k-10 02-24-2003 12:57 AM
Thanks for the info. Tuff Country has some good stuff thanks. I ve heard that with a shakle flip makes the tires uneven in the wheel wells? What about blocks has any body had any problems with them? Thanks
Mudder 02-24-2003 01:41 AM
Ive been running 4" blocks for years and never had a problem. Never run blocks in the front. Shackle flips will move the axle from the center of the wheel well.
Mike C 02-24-2003 01:36 PM
Black Diamond was originally owned and designed by Warn. They were sold to someone else last year. The original engineering was excellent, but no clue about present owners. Usually replacement rear leafs also slightly relocate the axle in the wheel well. Spend the extra money and get the leafs. You will not be unhappy.
'71k-10 02-24-2003 11:10 PM
Thanks for the input Mike C. I was thinking rear leaves too. I think i will go with this setup. let you guys know how it turns out.
