-   -   Torque value-Pitman Arm Nut?? (https://67-72chevytrucks.com/vboard/showthread.php?t=418851)
PRattenbury 08-29-2010 11:43 AM
As the title says, I am looking for the correct torque value to apply to the nut that holds the pitman arm to the steering box shaft. 1980 C10 SWB pickup, power steering. Thanks!
Justins76 08-30-2010 02:11 AM
Re: Torque value-Pitman Arm Nut??
My 74 service manual says pitman arm to pitman arm shaft nut 180 lbs ft power steering, 140 lbs ft manual. Pitman to relay rod 60 lbs ft. I would think 1980 with be the same values.
PRattenbury 08-30-2010 01:18 PM
Thanks! Now I gotta find a torque wrench that goes higher than my 150 ft/lb wrench does...
Slonaker 08-30-2010 02:29 PM
My torque wrench only went to 140 or 150. I pulled until it clicked, then pulled for one more grunt for good measure. :)
Slonaker
PRattenbury 08-30-2010 05:36 PM
I just ran mine up to 150. That's pretty tight.
mattcrp1 01-27-2016 07:58 PM
thanks
mattcrp1 01-27-2016 08:13 PM
Quick note, I hit with my 1/2 impact and then checked it with a 3ft torque wrench. It took some more turning with the wrench to hit the 180ftlb mark.
