-   -   Disc Brake Swap Donor Vehicle List? (https://67-72chevytrucks.com/vboard/showthread.php?t=421883)
69 1/2 Sixpack Bee 09-17-2010 11:57 PM
I **think** I read somewhere here that '73-'87 trucks' disc brake spindles and lower control arms bolt right up to our era trucks, right? My nephew wants to put discs on his '70 GMC and the later model trucks are much more plentiful around these parts. Will these parts bolt up? How about the booster, master and prop. valve too?
Thanx,
Bud
basemodel67 09-18-2010 12:22 AM
Re: Disc Brake Swap Donor Vehicle List?
Get the whole front crossmember with upper and lower arms attached... Should bolt right in:smoke:
SCOTI 09-18-2010 09:40 AM
Correct. 73-87 parts are a direct swap w/or w/o swapping the x-member too.
69 1/2 Sixpack Bee 09-18-2010 12:39 PM
Thanx!
