-   -   electric fan ??? (https://67-72chevytrucks.com/vboard/showthread.php?t=422118)
61apachespeed 09-19-2010 08:17 PM
electric fan ???
i have a 61 apache i am trying to put a electric fan in front of the radiator. both it hits the cross bars in front. what do the cross bars do?? and can i cut them out??
aerotruk63 09-19-2010 08:27 PM
Re: electric fan ???
They brace the rad support, could you remove them, they remove them when installing a condenser for A/C.
6863m 09-19-2010 09:08 PM
I just put a fan in my 62 and put it in front and it clears the pulley by about an inch. Is there a difference which side.
nachodog2 09-19-2010 09:23 PM
If you have the room and the interference isn't very much you can space the radiator a bit to move it towards the motor.
Captainfab 09-20-2010 12:33 AM
Typically electric fans work more efficiently as pullers.....on the engine side. Of course your fan has to be either reversable or already working as a puller. If you need to install your fan in front of the radiator, I would remove the X brace on the radiator support. None of mine have that X brace there and I haven't had any problems with the radiator support.
wlevick 09-27-2010 11:05 AM
Here is mine.
srsummers 09-29-2010 11:59 AM
What kind of HP increase do you gain when switching to an electric fan?
61_FL_Apache 09-29-2010 12:09 PM
5-10 maybe?
markeb01 09-29-2010 01:34 PM
More than the horsepower gain, I prefer the constant hum of an electric fan compared to the screaming you can get from a variety of stock and aftermarket fans at higher rpms.
Captainfab 09-29-2010 11:45 PM
I feel that your engine gets up to operating temperature quicker with an electric cooling fan(s)
Heater63 09-30-2010 01:17 AM
Yes, you're removing a load by eleminating the mechanical fan; But, you have to make a lot of electricity to run those electric fans; it takes more power from the engine to turn the alternator at a higher loading to produce that electricity. In fact, you might need to get a bigger alternator to add electric fans.
61apachespeed 10-01-2010 12:17 AM
i am running a 95 amp and a 2400 cfm spal eleic fan. i run about 180 to 190 temp. i have a 180 robert shaw themo.
