-   -   removing clutch pedal (https://67-72chevytrucks.com/vboard/showthread.php?t=423247)
brans72 09-26-2010 08:40 PM
I am going from 3 speed to Automatic, wondering best way to remove the clutch pedal from the truck. Steering cloumn is already out along with engine etc. Brandon
passthebuck 09-26-2010 08:55 PM
Re: removing clutch pedal
I had heard that the clutch pedal just "piggy backs" onto the brake pedal framework & simply unbolts, leaving you with just the brake pedal. I hope that somebody can chime in with more clarity on this...
LockDoc 09-27-2010 12:02 AM
That is correct. Take the spring off and the arm off of the right side of the shaft and slide it out...
LockDoc
timski69gmc 09-27-2010 12:20 AM
Yep, piece of cake!
altownsend 01-15-2012 12:05 AM
Do you still have that clutch pedal? I want to go back to a manual and need it. Thanks - Al
LockDoc 01-15-2012 12:31 AM
Unfortunately Brandon hasn't been on since the 19th of last month. Have you tried the parts board for one?
LockDoc
bobs409 01-15-2012 07:42 AM
LockDoc
Probably from removing that spring! If it's the big heavy one, it's one tough spring to R & R! Hope he ducked at the right time! :lol:
