-   -   6 cyl Power Steering Brackets (https://67-72chevytrucks.com/vboard/showthread.php?t=424326)
dabruce15 10-03-2010 08:41 PM
Can someone tell me if this is for an integrated head? What is the difference?
68chevyfuelie 10-03-2010 09:24 PM
Re: 6 cyl Power Steering Brackets
Looks like 292 brackets.
Livrat 10-03-2010 10:26 PM
They do not look like intregal head brackets that I have.. not sure if yours are for a 250 or 292
Dark Knight 10-03-2010 10:39 PM
Those are 250 non-integrated head PS brackets. They look just like the ones on my 250.;)
dabruce15 10-03-2010 11:32 PM
I was hoping that's what they are! That's great news.
dabruce15 10-10-2010 10:25 PM
Does anyone have a picture of these set up? I can't seem to find a diagram of them in my service manual.
dabruce15 10-11-2010 05:31 PM
TTT
NC67Chev 10-11-2010 06:24 PM
3 Attachment(s)
do these help?
dabruce15 10-11-2010 09:56 PM
Originally Posted by NC67Chev (Post 4235687)
do these help?
Thanks, do you have a better one of how the alternator is set up? The twisted bracket is throwing me off.
NC67Chev 10-12-2010 08:25 AM
2 Attachment(s)
Sorry about that, hopefully these will help for that.
dabruce15 10-12-2010 12:33 PM
That's what I needed. Thanks for going out of your way to post these. :metal:
NC67Chev 10-12-2010 12:47 PM
Another thing that might be throwing you off is the alternator adjustment bolt. You will remove it, and it will now go from the front through the slot in the saddle portion (the big part) of the bracket. Does your alternator have a double pulley on it?
dabruce15 10-12-2010 06:20 PM
Single...
NC67Chev 10-12-2010 08:27 PM
Well.....you might end up needing to put a double pulley on your alternator. I'm thinking your PS brackets will position the PS pulley to run on the 2nd groove of your water pump & damper. When I put mine on, the belt interfered with the nut on the alternator pulley. So, I took the alternator off and took it to a local alternator shop. They put a double pulley on for $15 (parts & labor). There are different configurations of these PS set-ups though, so you will need to mount if before you will know for sure.
I would suggest that you mount the PS bracket and put the belt on before you take your steering gear out. That way you can add the double pulley on your alternator before getting "stuck" with not having everything you need.
That said, the stock alternator brackets on yours look a little different than my '67, so it could be lower which might work to your advantage.
dabruce15 10-13-2010 06:24 PM
That's good advice. Especially since the truck is my daily driver. Thanks again for the pics and info.
NGN 02-05-2020 11:43 AM
Just reading this, very helpful information. Thanks all
NGN
Nick
