-   -   Modifications with larger springs? (https://67-72chevytrucks.com/vboard/showthread.php?t=426738)
THE "10" SILVERADO 10-18-2010 10:32 PM
Hello, I have been thinking about putting in about a 2 inch lift for my 77 but after a little thinking I'm pretty sure that I would be fine by putting in 3/4 ton springs instead of 1/2 springs....it will give me a little lift and let me tow a little more...I was just wondering what other modifications I would have to make for the 3/4 springs because my truck is just a C10 and made for the 1/2 springs...
I only put this in 73-87 because I want to know the things I need to change on a 77...
3r!c84 10-18-2010 10:41 PM
Re: Modifications with larger springs?
put 1 ton spings up front and put 3/4 ton leaf pack in the back
THE "10" SILVERADO 10-18-2010 10:47 PM
Can I get the one ton springs anywhere? I don't see them in LMC...just the 3/4 and do you know what mods I would need to do? Or do they just fit right where the old ones go?
3r!c84 10-18-2010 11:10 PM
check your junkyard. get them cheap. i got a set up 1/2 coils for 20$
old Rusty C10 10-18-2010 11:12 PM
or you could go to a spring shop and have them add leafs
Prerunner1982 10-19-2010 11:22 AM
For the front coils you need the HD coils in the LMC catalog. They only list Std and HD.
For the rear springs you may need to move the shackle mounts back to the rear holes for the 56" spring if you are putting in 3/4 ton leaf packs, unless you already have 56" springs. My 82 Chevy C10 (Camper Special) had the 56" springs and I think it even had 1 more leaf, my 87 GMC 1/2ton had 52" springs and 1 less spring than the 82 C10 had... both were longbeds.
