-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   sway bars (https://67-72chevytrucks.com/vboard/showthread.php?t=427317)
stich626 10-22-2010 02:56 PM
sway bars
whom makes them, front/rear 67-72
thanks..
PBFAB.COM 10-22-2010 03:10 PM
Re: sway bars
thanks..
We offer both front and rear bars for the C10.
PM me your number and I can call this afternoon and answer all your questions.
chapster 10-30-2010 02:00 PM
Re: sway bars
stitch,
Nate is working on a rear swaybar for me as we speak. You wont be disappointed.
ozman3803 11-03-2010 12:03 AM
Re: sway bars
you have any pictures of your front and rear sway bar set up Nate?
mongoose 11-03-2010 12:56 AM
Re: sway bars
do you make them for squares as well?
i'm looking for a set up for my blazer ATM.
stich626 11-03-2010 08:17 AM
Re: sway bars
I'll call when I know more of what I want out of this truck..
as I'm sure with a bbc it's gonna push bad, with the throddle being the turning partner
most likely 3" drop rear (2"block then coil, or maybe all coil) need to find out what will work better in turns.. and spring rates..
front, 2" drop.. again coil or spindle. have to see what is best to handle..
when I play :)
then (sway/anti roll bars)
as I want a neutral as I can get(I know thats ask'n alot with a bbc in the nose) and throddle overstear.. controllable tho.. not a fast snap from one to the other..
I had my monty SS set up so I could slide around corners, and if needed 4 wheel drifts and control it..
had a f150 that was a fast snap to total loose with no warning,, and I don't want that..
