'Burb Question
***MODS I know it is in wrong forum but more folks look here 1st***
Move if you must. I am new to Suburbans, 1967 ones anyway. Did they come from the factory with floor mounted A/C controls/vents? under the 1st rear bench seats is what I mean. Custom model 1967 C20 how can you determine the gear ratio? just get the numbers off one of the tubes? did they come from the factory with wood floor in the rear compartment? Thanks for looking. |
Re: 'Burb Question
your a/c is not factory. Dealer installed, or aftermarket.
gear ratio... depends on engine and tranny options. I say pop the cover off the diff and count the teeth. That's the only way you'll ever know. the cargo area in all panels and burbs were plywood. |
