why do my fingers fit in here??
Re: why do my fingers fit in here??
maybe door pins are worn out?
That's "how we made 'em"....
2 fingers is still tight.. :haha: ;)
Are those mini blinds in the door window?? :c2:
that looks like a reflection of vynal siding to me in the window lol
thats how we made em....
2 fingers is tight.... those 2 helped me out alot. doors almost perfect now. ill try and mess with the bolts tomorrow and see what happens... although to me the rest of the door looks like it lines up pretty good. up top, along fender etc. i did look at 2 bolts on the door area and noticed a color change, as if they may have been in one position at one time and now are at a different one. thanks for replies guys. |
2 fingers that spread apart is not tight in my book... lol
Also you might want to try and pull the top of the door inward with leverage. If the door is good everywhere else, I know that works for small gaps, but not sure about that gap. |
Do the body lines line up with the rest of the cab? I bet the bushing in the hinges are shot (or gone)...
has the truck ever had any damage on that side ?? x2 bushing in the hinges are shot |
maybe theyre 73 or 74 doors.. i heard those doors are just a tad smaller.. could be wrong though.. what do the inner doon panels look like? if they are real small, its an older door
edited for unfriendly to family content
this is a family friendly site.... please refrain from making remarks that could be taken in an offensive manner |
i messed around with it a little today. just loosended bolts and pushed and pulled door around. i was able to close the gap up top a bit, but then the lower end of the door near bed, was out....i played with it a bit, then was time to eat so i called it a day.
i am able to close gap up top....the one in the pics, but then the other end is out. might need more time playing, loosen, tighten, loosen tighten.... i dont think doors are old tho |
I had the same problem after i changed my door pins. it's just a matter of getting the top pushed in just a little to close the gap.
It will probably help to remove the door striker while doing all the lining up.
thanks. i thought it would have to be on to get it rite
It makes it a lot easier open and closing the door. You'll know when you get right. Then put the door striker back on and try it. Adjusting doors is a pain, guaranteed.
Get your body lines right, then pull the top of the door in.
