-   The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=38)
-   -   How is this removed? (https://67-72chevytrucks.com/vboard/showthread.php?t=430041)
79wagon 11-08-2010 10:34 PM
Im wondering how to remove the lower panel that holds the barn door latches on a 69 panel. Mine is completely rotted out, but i found one at a scrap yard, the only problem is its a upullit only yard and no torches are allowed. The panel in question goes where the yellow box is in the photo below. Any help would be appreciated
http://i258.photobucket.com/albums/h...524-02edit.jpg
sharpie1972 11-08-2010 11:37 PM
Re: How is this removed?
They are "basically" an unbolt item, but it's quite a bit of work. Cutting the plywood floor on the donor vehicle helps. The hard part is getting the panel out once everything is unbolted. You really need to either lift the body off the frame or cut the rear frame rails so you can drop this piece straight down. I'll post a few pics of one removed so you have an idea of what you are dealing with. Sharpie
sharpie1972 11-08-2010 11:42 PM
3 Attachment(s)
Mine is from a clam shell, but yours should be the same, less hinges. Sharpie
79wagon 11-09-2010 09:16 AM
Thanks sharpie. I cant do either (lift or Cut the frame) due to the restrictions on jacks and torches. But under the taillights its pretty rusted, so i might knock that rust out and try to work it out. Im just glad its not a welded part. lol. Again, thanks :)
71gmcburb 11-09-2010 05:55 PM
what about a battery powered saws-all? i have a yard near me that has the same restrictions but they allow batt powered tools. if you can at yours you can just cut the rear panels on the donor out and just lift it out
79wagon 11-09-2010 09:31 PM
I dont have a battery one though, or thatd be my plan. Ima see if anyone i know has one or knows someone with one. I hope they do, because the panel on mine is gone, literally gone. if a fly landed on it it would crumble. lol
